Wrong fliud in a M5R2
Old Oct 11, 2006 | 11:40 AM
T30's Avatar
T30
I recently aquired a 96 F250 from my company. The tranny has issues, grinding while downshifting, sometines while upshifting, also reverse seems to bind/clunk sometimes. I have learned that this tranny uses atf not gear oil, which is what is in it now. Will simply draining the gear oil be enough or should I use some sort of flush? What sort of damage could have been done by having the gear oil instead of mercon? Could the wrong fluid be the source of these issues?
Old Oct 11, 2006 | 12:48 PM
adrianspeeder's Avatar
Sure its the mazda? I've only seen it in the F250s behind the 302 in the early 90s.
Does it look like that? The more common for what you have ZF has diagonal ribbing.
Either way, get ATF in there, but I'm thinkin you'd need a rebuild.
Adrianspeeder
Old Oct 11, 2006 | 04:40 PM
T30's Avatar
T30
Yeah thats it. This is the 3rd tranny in this truck, maybe during a replacement they put a mazda in place of the zf? Which is more reliable? How hard would it be to switch to a better tranny, and which one would you recommend? Thanks for the reply.
Old Oct 11, 2006 | 06:33 PM
300, 302 or 351? 4x4?
If so, your gonna pay a mint for a ZF as thats highly desired by guys like me for swappin in our half ton F150s and Broncs. 4x2 ZFs are pretty cheap by default for the same reason though.
Adrianspeeder
Old Oct 11, 2006 | 07:53 PM
T30's Avatar
T30
300 4X2... Will I need to change crossmember, pressure plate, driveshaft, wiring, anything? Is this above the average shadetree's skill level?
Old Oct 25, 2006 | 07:09 PM
Pdx-Dave's Avatar
I have this same tranny (M5R2)
It screams in every gear except 4th, and pukes tranny fluid everywhere.
Old Oct 25, 2006 | 08:34 PM
T30's Avatar
T30
This sounds like a high quality tranny!
Old Oct 27, 2006 | 10:06 PM
Pdx-Dave's Avatar
Actually I think it is alright. I kinda like the whine when driving around town (on th highway gets annoying) and the rear main seal just needs replacing which is pretty normal for any tranny.
Old Oct 28, 2006 | 01:19 AM
dirtyd0g's Avatar
m5's are ok tranny's however the atf fluid ford used in them is crap. I use syncromesh in them. If it is making noise in all gears except 4th you have a bad bearing (probably the one linking the input shaft to the output shaft)
I like these transmissions in the 2.3 rangers but in the full size trucks they are a bit small IMO. The zf has it's own set of issues. actually I can't think of a moderm manual transmission I like in a large truck. Nothing really competes with the automatics for strength.
Alan
Old Oct 28, 2006 | 09:57 AM
The Rangers/Bseries/Explorers/Navajos/Aerostars use the M5OD-R1 dirtydog. The F-150/Bronco use the M5OD-R2. Totally different tranny.
Adrianspeeder
