VSS gear question
Old Sep 30, 2006 | 02:43 PM
superman78221's Avatar
VSS gear question
running 35in tires 4:10 gears and the 4.6 on my 97 f150 does anyone know the correct color vss gear i should be running to correct the speedometer
Old Oct 3, 2006 | 01:53 AM
fasterhorses's Avatar
I do not know which color. I do know that your speedo should be about 5% too fast based on 29" stock to 35" tires and 3.55 stock to 4.10 gears. If you have a buddy with a GPS you can take a drive and check the mileage to better determine the error. Assuming 5% is correct then count the teeth on the gear you have (should be 20) take it to Ford and ask for a VSS gear with 21 teeth (20 x 1.05 = 21). I doubt you will find one and I think they only made 3 gears 19,20,21 so more than 5% error and you will need something else. Here is the "Yellow Box" option http://www.blackrobotics.com/ Good luck
Old Oct 3, 2006 | 08:33 AM
ONELOWF's Avatar
Welcome to the forums. I got my 23 th here.
http://www.transmissioncenter.net/sp...___va.htm#ford
