Transfer Case Fluid
Old Sep 27, 2006 | 07:33 PM
jamwiest's Avatar
Question Transfer Case Fluid
How do you check and fill the fluid in the transfer case of a 1993 F-150? What kind of fluid do you use?
Old Sep 27, 2006 | 07:36 PM
BLUE20004X4's Avatar
I believe you stick your finger in the fill hole and you should feel some, if not top up with regular Mercon, not Mercon V. It should be Mercon anyways, it is in the 2000's that I know, but check you're owners manual, or wait till others chime in here. Ususally the transfer case is not much to worry about.
Old Sep 27, 2006 | 09:01 PM
adrianspeeder's Avatar
Mercon ATF works just fine. Bout two quarts.
Undo the fill plug first incase you strip it out and your not stranded with an empty 1356.
I replaced the stupid square hole aluminum junk with some brass pipe plugs from home depot.
If yours are stripped like mine were on the 88, you can take a scrap of steel stock and grind it down to pound in. Heck, I'll sell ya the custom made plug removal unit for a sweetheart of a deal.
Adrianspeeder
Old Sep 27, 2006 | 11:10 PM
jamwiest's Avatar
Thanks, mine leaks so I better check it.
Old Sep 27, 2006 | 11:13 PM
jamwiest's Avatar
Adrianspeeder
How do you get the fluid in there, take a mouth full and blow it in through a straw?
Old Sep 28, 2006 | 07:19 AM
I use a device called a suction gun which is just a grease gun with a different end on it. Bout ten bucks at a tool store. You could also use an old turkey squirter.
Adrianspeeder
Old Sep 29, 2006 | 04:21 PM
Bubbadewsky's Avatar
Easy refill
Use a small funnel and attach to it a section of plastic hose (got mine from tractor supply) Hang the funnel in the space between the back of the cab and top of bed, snake the plastic hose down between the cab and bed into the fill hole and fill ----works great
Old Oct 2, 2006 | 12:16 AM
OhioLariat's Avatar
Sounds like a great idea!
Andy
Old Aug 18, 2015 | 06:11 PM
93F1504X4BDS's Avatar
I did the brass pipe plugs from home depot. Work great! Thanks adrianspeeder.
Used Valvoline MAX LIFE full synthetic, DEX/MERC, MERCON LV Multi-Vechicle ATF
