J-Mod or Shift Kit?
Old Sep 3, 2006 | 10:21 PM
OhioLariat's Avatar
J-Mod or Shift Kit?
Hi folks.
I'm considering a shift kit for my '99 4R70W, but really like the price of the J-mod (free) if it's just as effective. Has anyone applied this mod to a 99+ 4R70W? What about the "improved components" I've seen listed? Do we newer-tranny folks already have them?
Truck is used for towing a 4,000# travel trailer, as well as occasional daily-driver-type use, and is a 1999 extended-cab 4x4 with the 5.4.
If the J-mod is not applicable or not recommended (why?), what have folks found to be the preferred kit for my usage?
All input will be welcome and appreciated. Thank you!
Andy
Old Sep 5, 2006 | 11:52 AM
dixiebandit69's Avatar
I did the Jmod on my 2wd 2000 F150 and love it! Just follow his instructions to the letter and you won't be disappointed.
So far I have not seen any shift kit that is as effective, harmless, and cheap as the Jmod.
It is also worth mentioning that I did the Jmod on my truck at 100,000 miles, and the previous owner had never changed the trans fluid. I did it anyway, and it has worked flawlessly ever since.
75,000 abusively driven miles later, I am still shifting hard and fast, and I can still burn rubber on the 2-3 shift. I have changed the fluid in the trans a few times since doing the mod, and I haven't had any excessive amounts of friction material or metal shavings in the magnet, just normal accumulation.
Do it. Do it now. You won't be sorry.
Old Sep 5, 2006 | 12:13 PM
MGDfan's Avatar
Hi.
First - do more research.... then decide.
J-Mods are not recommended:
https://www.f150online.com/forums/sh...highlight=jmod
Old Sep 5, 2006 | 04:23 PM
OhioLariat's Avatar
Thanks for the input.
I do recall seeing that the J-mod doesn't work as well for trucks. Maybe it has to do with the loads encoutered or the valving being different for a truck vs. a car?
In any case, I just talked with Gregg at Factory Tech, and it sounds like his modified separator plate should be just the ticket. (Being a '99, I don't need the whole valve body.) Only $85 from him directly, and the truck can easily be returned to stock later if necessary. Plus, I can choose to install the 1-2 and 2-3 accumulators/springs, or not, depending on how firm I want the shifts.
Now I have a decision to make. To do or not to do.....and how much to do if I do do.
Andy
Old Sep 7, 2006 | 06:16 AM
stratus183's Avatar
I picked up a Superior Shift Improvement kit from Napa for $45 and some new valve body gaskets from Ford for around $10 and it made a huge difference in the way the truck performs now! I love it.
