need some help
Old Sep 6, 2006 | 06:41 PM
treetrunks's Avatar
need some help
I am looking at buying a 94 f150 302 5spd 2wd and am wondering what i need to do to put a transfer case on it so i can put the drivetrain in my 99 tj. Any help would be appriciated. Tanks
Old Sep 7, 2006 | 02:46 AM
JMC's Avatar
JMC
25 Year Member
Need to know what you have for a transmission. You could need a new transmission and a t-case.
JMC
Old Sep 7, 2006 | 06:08 AM
treetrunks's Avatar
i believe it is a m5od
Old Sep 7, 2006 | 09:04 AM
JMC's Avatar
JMC
25 Year Member
If it is an M5OD then you will need a 4x4 transmission. The 4x2 output shaft is too long to allow a transfer case to bolt to the adapter once the adapter is bolted onto the transmission.
JMC.
Old Sep 7, 2006 | 11:46 AM
treetrunks's Avatar
Thank you very much. So it is possible with the zf to change it to 4x4? just not the m5od
Old Sep 7, 2006 | 12:26 PM
adrianspeeder's Avatar
No, you need a 4x4 ZF or M5OD to bolt a xfer case directly.
Adrianspeeder
