1999 4R70W - Drain Plug on Torque Convertor?
I was just curious if the 4R70W in my 99 F-150 (4.6L) would have a plug on the torque convertor?
I am asking as I can get the pan removed, cleaned out, new gasket, new filter and refilled for under $60 at a local shop. He said if the convertor has a plug them they will drain that too.
Sounds like a good deal to me as it is going to cost me around $30-$35 for the fluid and filter alone.
My 1999 F150 has a torque converter bolt on it. I just removed the round rubber bell housing torque converter bolt window cover thingy (dang, that should be a song I think) and turned the converter by hand with a screwdriver (there are some gear teeth inside the hole on mine) until I saw the bolt.
It was an itsy bitsy teenie weenie yellow polka-dot bikini.
It was an itsy bitsy teenie weenie torque-converter window thingy
