Last edit by: IB Advertising
Grinding Noise on 2004 F150 4x4
Some describe it as a blender with ice, other a grinding noise. Whatever it is, it’s annoying and can be harmful to your truck. Find out what other did to solve the issue and what caused it.
Helpful Advice
Read full discussion for further information
Helpful Advice
Intermitent Grinding Noise on 2004 F150 4x4
I have a 2005 F-150. The grinding noise started for me too but usually when I start going up a hill or someplace where it requires to shift. It goes away sometimes but every few miles, it happens again but for a short time. Then, I hadn't driven my truck in about 3 weeks. The grinding noise was really really bad and it lasted a long time. After I drove for 45 minutes, it went away. Then driving back, it came back but like it did the first time. Like i'm driving over the rumbling strips at the shoulder of the road. What could this be? Please don't tell me it's my trans. It's a 4x4 with over 200,000 miles on it. Was driving really nice. Almost like a new truck. Note: I have no problems other than the grinding noise on the shifting.
I have almost 185K on my tranny. 5.4 lariat. I have changed the fluid more than regular serv as I have towed a lot. I am gettign the metallic/shimmering (for lack of a better term) noise when shifting from 2nd to 3rd as well as some shuddering. It sounds like the engine is dieseling at times.
I checked the fluid and it's at reg level and clean as a whistle. Does this sound like the IWE solenoid or vacuum problem or maybe the thing is on the way out? I just paid it off so it makes send that something would go!
I did have a new rear end put in a few months ago and it whirrs/moans when coasting, which it never used to with the old one. I think the dealer might not have used the same replacement gears. Would this contribute to any tranny issues?
I should add that I rarely use 4WD
-Chris
-Chris
I just had this happen to my 06 f150 while driving home, i thought it was a rock or something stuck so i said heh it will fall out as a slowed down to approx 30-20km/h a thump happened and then went away. (engaged into 4x4) i suggest to drive in 4x4 until you get the issue resolved. This was NOT a recall/silent recall by ford, and is only covered if still under warrenty.
Hope this helps
I have been following this post for awhile and experiencing same things,, i changed the solenoid switch ,still nothing ,,, going to check vacuum leaks to hubs next ,but noticed today battery light comes on ,changed battery ,, now got on highway and did grinding noise and noticed the charge gauge shoots up to the high level ,, what is up with that... any ideas...
I am having a similar issue with a later model F150. My 2010 is making this noise every couple of days. Seems to have started after I had new tires put on. Not sure if I should go to the tire store or my dealer. Warranty is no longer valid.
Thanks!
Guys -
I just wanted to say a big THANKS for this thread. Just bought a used 2006 F150 on Friday and Saturday morning I drove it with the windows open and hear "the noise". The previous descriptions in this thread nailed it and made it really easy to diagnose. They're ordering the solenoid today and hopefully that's the end of the story.
I don't know how long this has been going on though - what other damage may have resulted from this problem?
Guys -
Again I was amazed at the idiotic design that placed the IWE solenoid right where all the rain water dumps on it. Fixed that with a piece of EPDM Peel and stick flashing.
I thought I was going nuts...
Driving home from work the other night I heard a noise that sounded like I had run over a metal fence post and it was dragging beneath my 2005 F150 4X4 Super Crew with about 160,000 miles. It scared me and I pulled over in an empty parking lot and got out, looked up the street to see what I hit. I saw nothing so I procured a flashlight and crawled beneath the truck to see what was amiss. Once again, NOTHING! About three days later, it did it several times (always around 30 MPH) but I then noticed that it was a metallic sound, like gears trying unsucessfully to mesh, but would quit when I braked to under 10 MPH. I checked this forum and found about the problems others were having with the IWE vacuum solenoid. Saturday, I went to my dealership here in town and the parts department was closed so I drove to the AutoZone store. They had the replacement I needed with a lifetime limited warranty for roughly $30 (plus 10% discount if you have a valid military or retired military ID) so after taxes and discount, I paid $29 + change. My original part number was E8AE-9H465-BA and the replacement part I purchaced at AutoZone was a Dorman 600-400. The Dorman part was mounted on a bracket which included the rain shield and since, I have driven the truck about 190 miles on highway and city streets and have yet to have the problem occur again. I am hoping this has fixed it once and for all.
