Shuddering during shifting
Old Jan 3, 2005 | 10:33 PM
Studrock923's Avatar
I have a 1997 F150 with a 4.6L V8, 148K miles that has a transmission that shutters when I accellerate on the gas. I was planning to have the transmission flushed and replace the fluid but have read some of the posts here and it seems that replacing the plug/plug wires/cap and rotor should fix that problem. Do you agree?
Old Jan 3, 2005 | 10:52 PM
dirtyd0g's Avatar
Re: Shuddering during shifting
I agree they may fix the problem and should be done first..
Old Jan 4, 2005 | 07:40 PM
Yankee7985's Avatar
Well, since your truck doues not have a cap and rotor, having the other items done should help your issue. Typically the tranny flush helps a lot.
Old Jan 4, 2005 | 08:31 PM
97snw's Avatar
i had the same problem get your tranny fluid changed and ADD Lube Gard in a Red Bottle.I got my at my local Napa parts store.It does work really never had the problem come back.
Old Jan 5, 2005 | 06:14 PM
dirtyd0g's Avatar
The red lubeguard is to prevent sticky valves. It is good stuff and I won't knock it ,but it would have no effect here. The green lubeguard is mercon V additive to convert mercon to Mercon V. I have tried it a few times and sometimes didn't give me any problems. It doesn't seem to be enough to me, maybe a couple bottles would work, but I'd sooner just buy the mercon V fluid. You just needed to change your fluid or your fluid was low.
Alan
