F150 driveline compared to F250?
Old Nov 22, 2004 | 01:14 AM
Phil @ FLP's Avatar
How do the F150 and F250 driveline compare? Tranny, differentials, and transfer cases? Are they the same or different? Im planning on doing a hi horsepower F150 but want to see if it would be beneficial to swap in F250 driveline parts. This is reffering to the recent F150s and F250s from 97-04.
Old Nov 22, 2004 | 09:45 AM
JMC's Avatar
JMC
25 Year Member
The superdutys use the 4R100 tranny. So does the Lightning. The Superdutys use a Dana 60 or 70 10.50 differential. The F-150 uses either a Sterling 8.8 or a 9.75. The weight penalty for using a 10.50 vs a 9.75 doesn't justify extra strength. The 9.75 should hold up just fine. Check out what the Lightning guys are using.
Regards
Jean Marc Chartier
Old Nov 23, 2004 | 11:21 PM
Ggg's Avatar
Ggg
In 97 they (F150,F250) both used the same E4OD and t-case. 98+ they both went to the 4r100 and still had the same -case.
92+ F250,350 SRW (except fpr the Light duty 250) used a Sterling 10.5 full floater rear end not a Dana. The light duty 250 used a unusual semi-floater with 6 or 7 lugs. F350 DRW used a Dana 70. Yes there are a few exceptions to the rule, I have owned two 96 250, 4x4, auto, PSD's with the same GVW at the same time and one had inboard drums and the other had outboard drums. I have seen a lot of drivetrain carnage but the 150's seem to keep their rear diffs in tact. I think mostly due to light trucks (read as not enough traction) and relatively low torque #'s. No I am not knocking the 150's, I said it was a relative term. Besides its torque combined with traction that breaks diffs. I would be more woried about the trans.
Old Nov 24, 2004 | 01:27 AM
JMC's Avatar
JMC
25 Year Member
How much power are we talking about?
JMC
