3.08 Gears To 3.55 Gears
LOOKING FOR "GLEN MC"
IM HOPING TO CHANGE FROM 3.08 TO 3.55 GEAR RATIO. WOULD LIKE SOME STEP TO STEP INSTRUCTIONS OR WHERE YOU GOT YOU INFO FOR DOING YOUR TRUCK. THE TRUCK IS A 97 F-150 XL 4.2L 5 SPEED. IM LOOKING TO GET MORE PULLING POWER OUT OF IT, AS IT IS VERY WEAK NOW WITH 33" TIRES ON IT. WHATEVER INFO WILL BE APPRECIATED. AFTER READING YOUR POSTS ON DOING YOURS IT SEEMED YOU KNOW WHAT YOUR TALKING ABOUT. IM VERY EAGER TO MAKE THIS SWAP. THANKS
Is it a 4x4 if it is you need to change both front and rear. It should not be a problem changing about 600-800 to install in 4x2 double for 4x4. do a search for this .
https://www.f150online.com/forums/sh...changing+gears
try this one.
try this one.
if i was in your position and had the cash, i would go with at least 3.73's or even better 4.10's in order to turn those 33's. I think you will be disappointed with only 3.55 in the long run. just my opinion.
