1989 c6 -> AOD conversion Q
Old May 14, 2004 | 06:16 AM
JBonDSS's Avatar
Hi guys
My 1989 f150 lwb with a C6 trans, I was wondering if it is possible to upgrade to a AOD??
i'd just like to get the rpm down on the highway & when just cruising around.
Will the box fit?
Wot other mods are required to get to phyically fix?
How do i can the column shift selector
Thanks for you help
James
Old May 16, 2004 | 12:13 PM
Tailgator's Avatar
Yep, they'll interchange, since you could get a AOD trans in the '89 F 150 behind most all the engines. A trip to some of the local boneyards should provide you with all the parts you need to make the swap.
