Transmission Shudder?
Old Mar 4, 2004 | 09:41 PM
KY_Ford_Man's Avatar
I have read several posts about transmission shudder and am wondering if that is what my problem is. I have a 1999 4.6 L that seem s to shake when starting up an incline. This usually happens on the highway in overdrive, but can also happen at slower speeds. I am assuming it's a torque converter problem but have limited experience. Any ideas?
Old Mar 5, 2004 | 01:30 PM
01screw's Avatar
Could be, but then worn plugs, bad coil, dirty gas filter could also cause the same symptoms.
Old Mar 6, 2004 | 02:50 PM
davidac's Avatar
I had a shudder in a Continental that I used to own before Ford bought it back as a lemon. After tune up that dealer required before trying to diagnose a 'driveability" problem, and after balancing tires (per Dealer), they finally located a bad modulator valve. Fixed and ran fine til next problem.
Old Mar 6, 2004 | 04:44 PM
MarAgt's Avatar
Transmission Fluid. I've seen this topic on other sites and I was having the same problem. I drained the ATF from the transmission ATF pan and the torque converter. Put in a new filter. Replaced 15 qts of Mobil 1 ATF, no more shudder. The shudder is a sympton of bad fluid.
Old Mar 6, 2004 | 10:12 PM
Thanks for the input. I'm going to try the fluid and filter change first. I have put about 20k on it since I bought it (90k now). Probably needs to be changed regardless.
Thanks!
