Change Fluid???
Old Feb 15, 2004 | 11:14 AM
whitescrew01's Avatar
Change Fluid???
I have an 01 Screw w/ 33k and was wondering when I should have the fluid changed?
Old Feb 15, 2004 | 12:28 PM
powerstroke73's Avatar
If you pull anything, haul anything, or run bigger tires I'd do it about every 20k. Since mine will be pulling about 5k on a regular basis I go about 15-20k between flushs.
Old Feb 17, 2004 | 03:29 AM
rkjerue's Avatar
If your tranny uses non-synthetic Mercon, the lubricating properties in the fluid start breaking down after about 30K, that's normally when you would change it. If you have the synthetic Mercon V fluid, the lubricating properties never break down, but the fluid still gets dirty, so it won't hurt to change it at 30K either.
Old Feb 21, 2004 | 09:03 PM
03f150man's Avatar
if you are not pulling or offroading, change it at 60,000 miles. when you do change, then change the tranny and torque converter fluid.
Old Feb 21, 2004 | 11:55 PM
temp1's Avatar
I would change it every 30,000 for peace of mind if you have the money...
This was my transmission filter at 39,000 miles...
And the pan magnet...
The pan magnet comes off and all those metal particles can be wiped off...
Old Mar 6, 2004 | 04:58 PM
MarAgt's Avatar
That's how mine looked at 42,000. I drained both the torque converter and pan, replaced the filter, and added 15.5 qts of Mobil 1 ATF. Nice and clean again and the common Ford transmission shudder was gone.
