2001 transmission
Old Feb 11, 2003 | 10:15 PM
67camaro's Avatar
2001 transmission
Does anyone know what type of transmission the 2001 supercrew 4x4 has in them?
Also I'm looking for the overdrive gear ratio # so i can figure out a cruising RPM with a gear change.
Old Feb 11, 2003 | 11:27 PM
SSCULLY's Avatar
If memory serves me correctly, all 4x4 have 4R100 trans in them.
As for the OD ratio, got me don't have a 4R100, and not in front of my Service manual CD right now to look it up.
I'll try to remember to take a look later, if nobody posts the answer.
Steve
Old Feb 11, 2003 | 11:42 PM
beastie's Avatar
When you open the door to your truck, look to the right on the door jam, and you will see a white sticker, look up your tranny code, if it is "U" you have the 4R70W, otherwise it will be the 4R100, I dont know the code for it. Gear ratios are as follows:
4R70W
1st - 2.84
2nd - 1.55
3rd - 1.00
4th - .70
4R100
1st - 2.71
2nd - 1.53
3rd - 1.00
4th - .71
Old Feb 12, 2003 | 01:39 AM
greencrew's Avatar
Mine is listed as: 4R70W 4 SPD AUTO
Old Feb 12, 2003 | 08:22 PM
67camaro's Avatar
Mine also was a "U".
