quick question
Old Jun 10, 2013 | 06:25 AM
broncomaniac66's Avatar
quick question
i have a 2006 f150 xlt triton with a 4.6 ( i assume the liter size off of the 10 bolt pattern on the rearend housing) i could be wrong, but ive tried fords self help but cant get it to work ,i need to know the towing capacity please,
thanks
s.c.b.[broncomaniac66]
Old Jun 10, 2013 | 08:00 AM
Colorado Osprey's Avatar
We'd love to help you but need more info:
Trans: Auto or manual
Rear Diff: Gear Ratio
4x4 or 4x2
Cab Size- standard, extended, screw
Engine Size: 4.2, 4.6, 5.4
Long Bed-Short Bed
Without the specs we would be guessing. The low end towing in the '06 was 6000lbs up to a high of 9500lbs.
With the info given that's the best I can do.
Old Jun 10, 2013 | 11:51 AM
1. Standard, extended, or crew cab?
2. Bed length?
3. 2wd or 4wd?
4. What is the 8th digit in your VIN?
5. Look on the door jamb sticker and post the following:
GVWR
Trans code
Axle code
5. Does it have a factory receiver hitch?
Old Jun 10, 2013 | 12:06 PM
mkosu04's Avatar
just check to towing guide for your model year
http://www.hillerford.com/resource_l...wing_guide.pdf
Old Jun 10, 2013 | 12:29 PM
Good guide, but you need most of the asked for info to properly read it.
