1300lb Payload seems low...
This is borrowed from a trailer form. The Payload seems quite nice .
This is spec'd with a Crew Cab XLT trim and the HD payload Pkg (8200 GVWR) which puts the payload at 2643 lbs. In a supercab configuration it will push up several hundred pounds, close to 3k. There are plenty of these out there pulling TT's all over the country.
Weight Information for F-150 crew cab with HD payload Pkg and 3.5L EB
Trim Curb Weight
5554.00 lbs
Gross Axle Wt Rating - Front
3750 lbs
Gross Axle Wt Rating - Rear
4800 lbs
Curb Weight - Front
3150 lbs
Curb Weight - Rear
2404 lbs
Reserve Axle Capacity - Front
600.00 lbs
Reserve Axle Capacity - Rear
2393.00 lbs
As Spec'd Curb Weight
5557.00 lbs
As Spec'd Payload
2643.00 lbs
Maximum Payload Capacity
2646.00 lbs
Gross Axle Weight Rating
8550.00 lbs
Curb Weight
5554.00 lbs
2993.00 lbs
Gross Vehicle Weight Rating
8200.00 lbs
Trim Curb Weight
5554.00 lbs
3750 lbs
4800 lbs
Curb Weight - Front
3150 lbs
Curb Weight - Rear
2404 lbs
600.00 lbs
2393.00 lbs
5557.00 lbs
As Spec'd Payload
2643.00 lbs
2646.00 lbs
8550.00 lbs
Curb Weight
5554.00 lbs
2993.00 lbs
8200.00 lbs
