haul Grizzly+TT
Old Apr 28, 2011 | 12:43 AM
tbaz's Avatar
haul Grizzly+TT
how would i tow my 700 grizzly with the TT, the gate down will hit the tanks. cant figure it out for the 5.5ft box.
Old Apr 28, 2011 | 01:00 AM
noregrets's Avatar
build ramps to drive up on or buy one of those pre made ones.
http://edmonton.kijiji.ca/c-cars-veh...AdIdZ270136968
Something like that or a sled deck works too but they are pretty bulky and big.
Old Apr 28, 2011 | 07:57 AM
APT's Avatar
APT
My guess is you don't have enough payload anyway.
Tailgate off?
Old Apr 28, 2011 | 01:02 PM
jerrybizzle's Avatar
Should have got the 6.5 bed, but you have what you have now. Here's mine with a 4 wheeler and a dirtbike in the bed pulling my camper. I am probably a little over weight limits but it does pretty good. In your situation I would just take the tailgate off and that should work for you. I used to have a gmc crew cab with the mini bed. The long box screw was my main reason for getting a Ford.
[IMG][/IMG]
Old Apr 28, 2011 | 01:19 PM
tbaz's Avatar
that seller with the ramps says the gate still wont close on a 5.5, not comfortable with half the rear tires hanging over where the gate is , guess im SOL.
Old Apr 28, 2011 | 01:35 PM
How far do they hang out the end of the bed? U don't think it would work with the tailgate removed? U could also build ramps across the bedsides that will haul the wheeler up high. Wind resistance would be high, but it may work for u. Where there's a will there's a way.
Old Apr 28, 2011 | 05:34 PM
goducks's Avatar
JUst take tha tanks off and throw them in the truck, put them on when you get to where your'e going. If you build some rails for the wheels to sit on long enough to catch the rear wheels of the ATV and run them to the front so the whole ATV is on them that should support it enough. Then get some ramps to load it with. You could just fix a piece if angle up near the cab that the front of the rails would slide under and fasten to. Make it easy to take them out when not needed. I would use some aluminum ramps for the rails in the truck and another set to load it with. Then get some heavier springs or airbags for the rear cause you will be overloaded.
Old May 5, 2011 | 09:38 AM
ZSK's Avatar
ZSK
Do you have any pictures of your trailer and hitch setup? You might be able to get a longer draw bar and relocate the tounge jack and be just fine...
