Battery Isolator
Old Mar 15, 2001 | 07:47 PM
ACOLEY's Avatar
Post Battery Isolator
I have a 2001 F-150 supercrew with the tow package. Does this include a battery isolator? If I leave the trailer hooked up to the truck will it drain the battery on the truck to charge the battery on the trailer?
Also has anyone installed a solar powered trickle battery charger on their RV's? Do they work well? How much do they cost?
Thanks in advance.
Old Mar 17, 2001 | 12:10 AM
Jimb's Avatar
Post
Nope. The battery circuit is only hot when the key is on.
1999 F-150 XLT
4x2 Supercab
139" WB Styleside
DOB: 7/19/99
Exterior: Dark Toreador Red
Interior: Dark Graphite 40/60 Split Bench
Optional Equipment:
  • 4.6L EFI V8 Engine
  • Electronic 4-spd Auto O/D
  • P255/70R-16 OWL All-Season
  • 3.55 Ratio Limited Slip Axle
  • Floor Mats - Carpeted
  • 6050# GVWR Package
  • Sliding Rear Window
  • Trailer Towing Group, Class III
  • Premium Electronic AM/FM W/CD
  • 6-way Power Driver's Seat
  • Remote Keyless Entry
  • Air Conditioning
  • 4-W ABS/4-W Disc
Added:
  • A.R.E. LSII Hard Tonneau - $745.45
  • Ford drop-in Bedliner - #F75Z-9900038-AB - $211. installed
  • Ziebart rustproofing - $279.
  • Smittybilt nerfs, textured black - #FN1730-S4T - $210.
  • Ford molded splash guards, front - #F65Z-16A550-CE - $33.33
  • Ford molded splash guards, rear - #F65Z-16A550-DD - $33.33
  • Ford Locking Gas Cap - #F75Z-9030-GA - $19.43
  • Spare PATS Key - $20.95
  • Tekonsha Envoy #9040 brake controller - $89.95
  • Fox WeatherBoot Floor Liners - #198 - $119.
1998 Windstar
1993 Taurus
1999 Casita
Old Mar 17, 2001 | 05:08 PM
Ian N's Avatar
Post
There is a relay in the engine bay relay box that sends power to the hitch plug only when the ignition is on.
You should make sure that it is there. I found out that mine wasn't installed at the factory (I do have trailer tow) and my trailer was not getting charged!
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
WMS Tube, Bassani Cat Back Exhaust.
Superchip Flipchip on Order
Old Mar 18, 2001 | 04:32 PM
mjhind's Avatar
Thumbs up
There were two relays in the bag with the wire harness for the trailer brake from the factory. I just plugged them in when I installed my trailer brake.
