help with towing with a 5.0
Considering my last truck (99 Ranger with 4.0 V6) towed my 19' boat with little complaining, I would think you'll be ok...
Can't wait till summer so I can see how my
98 F150 4x4 does with it
Hope that helps
Hope that helps
Will my 5.0 4x4 be ok pulling a trailerthat weighs 1700 lbs empty. I plan on putting some funiture in it. Ill be pulling from Va to FL. Is their anything i should do before i pull a trailer. The trailer is one of those van trailers from U-haul. thanks for any advice. jimmy
1996 F-150 EB edition 4x4 302, 3" body lift, 33s BFG All Terrain K&N air filter Viper 550 remote start with window mods (makes windows go up and down from remote) Alpine 3 disck in-dash cd player Infinity Kappa 5x7's in back and 5" mids with tweeters in front, PPI 6600 amp And of course a F-150 Online Sticker on camper shell
future mods: airaid and superchip
www.zing.com/album/?id=4294576377
You should be fine for power. I would add a transmission cooler if you don't already have one.
The UHaul trailers have surge breaks, so you don't need a controller or anything, just a 4 prong plug.
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
I had a '90 Bronco 4X4 Eddie Bauer 5.8L and towed a, loaded, 12'X8' U-Haul from Seattle to Washington DC (3400 miles). It was during the summer, no problems at all. Pulled it over the Rockies and Appalachians without overheating, or loss of performance. The only issue (not really a problem) was I had filled the power steering reservoir prior to leaving and it ended up being over-full, so it pushed some out around the cap. The only thing it did was get it on the trailer, and all over the underside of the truck.
You shouldn’t have any problems at all. Good luck!
