How much can I tow
Old Nov 25, 2000 | 09:19 PM
chezzy-chazz's Avatar
Post How much can I tow
Hi I'm a new owner of a 2000 f-150 x-cab 2wd
4.6 auto 3.08 gears.My truck came with a class 111 towing package #535.Realistically how much weight can I tow with this setup?
Can anyone answer?
Old Nov 26, 2000 | 10:11 PM
Mav's Avatar
Mav
Smile
Your truck will reasonable tow 3000 -5000 lbs. depending on what it is and the terrain you are towing it through.It WILL tow more than that but it will work its ***** off!
Old Nov 29, 2000 | 11:49 PM
anteater's Avatar
Arrow
You don't say whether your towing in hills or not! Your motor will tow up to 7000lbs, but not with such a low rear-end. If your in flat ground, you'll be ok to that point. The truck itself has enough mass to it to tow and more importantly to stop more than 7800lbs.
2001 Screw XLT
Oxford White, 5.4L,
Towing, Posi, Slider
Power seat, keyless
bedliner, Ford tonneau
Old Dec 10, 2000 | 12:00 AM
JD's Avatar
JD
From: Las Vegas, Nevada (originally from Kearny, New Jersey)
Post
Do a search of this entire site. The towing forum is still relatively new considering the age of the board. There are so many variable factors involved, i.e. tongue weight of item towing, GCVW, wind resistance etc....
I've towed heavier trailers easier than some lighter ones, those factors play a big difference with a truck of your setup.
