Airlift Wirless Air Compressor
Old Feb 11, 2010 | 04:33 AM
navyseal323's Avatar
Hey there i just installed a Airlift Wireless Air compressor mounted it ran the lines to the Ride Rite air bags and did everything but one thing . Connect it to the battery . So that being said i have everything routed have the battery connection ready to go except there is a red-white wire . Instructions say to splice into the ignition wire . Thats where im running into a problem . I dont know where to splice into .Much help is appreciated
Truck Specs
07 F-150 Supercrew Lariat 4wd 5.4 L Engine
Old Feb 11, 2010 | 08:26 AM
Colorado Osprey's Avatar
By ignition wire, they are looking for a keyed powered source so that when the truck is off there is no power going to the unit.
I would find a local source depending on where the compressor is mounted.
If you mounted the compressor in the rear half of the truck I would get the power source from the trailer charge line as a source. If you are in the front half of the truck, there are plenty of unused switched sources in the fuse panel.
Old Feb 11, 2010 | 04:05 PM
408F150's Avatar
the accessory (switched) wire is also very easy to locate behind the radio if you already have been working in that area.
Old Feb 12, 2010 | 02:30 AM
Thanks guys for all the help . I ended up taping into the radio's power source and it works great . Thanks again for all the help
