Will I
Old Jan 24, 2010 | 08:07 AM
FX4Firefighter's Avatar
Will I
Will i be able to tow this I have a 2006 Lariat 5.4 3.73 gears all stock truck and was wonder if it was possiable to haul this is so what would i need besides a WD hitch and a Brake controller
SORRY WRONG TRAILER
this is the one we are looking at
http://coachmenrv.com/products/model...20Ultra%20Lite
If Not what the max i should be looking for
Last edited by FX4Firefighter; Jan 24, 2010 at 10:09 AM. Reason: Wrong trailer model
Old Jan 24, 2010 | 08:38 AM
MGDfan's Avatar
Originally Posted by FX4Firefighter
Will i be able to tow this http://coachmenrv.com/products/model...eries=Catalina I have a 2006 Lariat 5.4 3.73 gears all stock truck and was wonder if it was possiable to haul this is so what would i need besides a WD hitch and a Brake controller
That's pusing the envelope, IMHO.
You are not gonna be happy towing that any distance with an F150.
Old Jan 24, 2010 | 08:41 AM
Fjkiss's Avatar
not safely
a biger truck
when some SOB cuts you off Your truck can't handle the load your going to ask it to (STOP or TURN) just look next to you and ask yourself if you want to put them at risk?
IMO Frank
Old Jan 24, 2010 | 11:36 AM
05crewzer's Avatar
technically your truck can tow it. but loaded down for a trip and i think i would agree with the others on safety.
Old Jan 24, 2010 | 11:38 AM
bigdad8214's Avatar
Little on the big side of a 150
Old Jan 24, 2010 | 02:27 PM
Too much trailer for any 1/2 ton truck unless you will only be pulling it twice a year to and from your remote site. This is not something you want to be hauling cross country or every weekend. I'd look at getting a smaller trailer or a bigger truck.
Old Jan 24, 2010 | 02:31 PM
Colorado Osprey's Avatar
SORRY WRONG TRAILER
This is a"towing guide" link from the top right of their website:
http://coachmenrv.com/owners/guide/a...ow-ratings.pdf
F-150 SuperCab, Conventional Towing,
Automatic Transmission
Vehicle Engine Tow Limit (LB)
SC SWB 2WD 4.6L V-8 6,300b
SC SWB 2WD 4.6L V-8 6,800c
SC SWB 2WD 5.4L V-8 7,700b
SC SWB 2WD 5.4L V-8 8,200c
SC LWB 2WD 4.6L V-8 6,400b
SC LWB 2WD 4.6L V-8 6,900c
SC LWB 2WD 5.4L V-8 8,600b
SC LWB 2WD 5.4L V-8 9,500c
SC LWB 2WD H-D 5.4L V-8 5,800c
SC XLWB 2WD 5.4L V-8 9,500d
SC SWB 4WD 4.6L V-8 6,000b
SC SWB 4WD 4.6L V-8 6,500c
SC SWB 4WD 5.4L V-8 7,400b
SC SWB 4WD 5.4L V-8 7,900c
SC LWB 4WD 4.6L V-8 6,200b
SC LWB 4WD 4.6L V-8 6,700c
SC LWB 4WD 5.4L V-8 8,300b
SC LWB 4WD 5.4L V-8 9,300c
SC LWB 4WD H-D 5.4L V-8 5,600c
SC XLWB 4WD 5.4L V-8 9,300d
Short Wheelbase=126 inches; Long Wheelbase=144.5 inches; Note: Reduce
maximum trailer weight by 500 LB for models with 18 or 20-inch wheels.
__________________________________________________ ____________________________________
According to their numbers you'll be overloaded in all but a couple of F150's
Old Jan 24, 2010 | 03:19 PM
Harper 184's Avatar
SORRY WRONG TRAILER
You can pull it as long as you have a brake controller and your hitch. I wouldn't take a cross country run with it because it will cost in gas. I guess it just depends on how far you plan to pull it. If you just plan to take it maybe to the lake or campground (being an hour or two away) it will be fine.
My travel trailer it heavier than that and i have pulled it with my 150 several times. although I don't do it much anymore because I have a powerstoke that does my dirty work for me.
Old Jan 24, 2010 | 04:29 PM
YDM's Avatar
YDM
The GVWR of the TT is fine for your truck. It's the tongue weight you need to be concerned with. At over 800 lbs. advertised tongue weight, you will likely be over 1000 lbs loaded up with batteries, propane, clothes and shoes in your bedroom cabinets, etc. which will exceed your stock hitch rating.
Since the TT is a rear kitchen model, you can manage tongue weight by loading more stuff toward the rear of the TT. But be sure that you maintain at least 10% of the total GVWR of the TT as tongue weight to ensure towing stability. The TT you're looking at has a GVWR of about 8800 lbs. If you keep the tongue weight at 10%, then even if you load the trailer up to the max capacity, you won't exceed the truck's hitch rating.
I went through this same scenario with my TT that has a GVWR of 9000 lbs. I managed to keep tongue weight at 875 lbs. loaded and ready to travel. The truck handles the weight well and with the addition of air bags, I am able to stiffen the rear up a bit for more control.
Old Jan 24, 2010 | 07:41 PM
dale29's Avatar
3/4 ton diesel, maybe even a dually (1 ton)
Old Jan 24, 2010 | 08:40 PM
05crewzer's Avatar
uuhhh no. thats alittle much. give our trucks a little break.
Old Jan 24, 2010 | 11:01 PM
Harper 184's Avatar
It's really not that heavy, I have pulled my travel trailer (8100lb) on an 8 hour round trip with a 00 F150 ext cab with 3.55..just make sure you have a load equalizing hitch, and a brake controller.
If you have a load equalizing hitch it will spread the weight of the tongue across all four tires and keep it from swaying. Your brake controller will take care of any stopping issues. This travel trailer is perfectly in Ford accepatable ratings.
I would suggest asking the company that is selling your travel trailer if they though it is acceptable to pull that camper with an F150...where I live there is a huge lake and camping with travel trailers is a big deal around here and I see F150's pulling Captivas ultra lite models that size and bigger all the time.
Old Jan 25, 2010 | 10:06 AM
APT's Avatar
APT
I recommend RV's with GWVR under 7000 pounds for 1/2 ton trucks.
How many people will traveling in your truck? What's the payload sticker on the driver's side B-pillar say?
Old Jan 25, 2010 | 04:18 PM
You WILL (not "might") be over one or more of the truck's ratings. Your call whether to do it or not, but I personally wouldn't except as I already indicated.
Old Jan 25, 2010 | 09:10 PM
05crewzer's Avatar
total weight of truck, trailer, people and gear is what we're saying is unsafe. tongue weight on that trailer is higher than average and thats why YDM was saying to put more gear in the back to not add tongue wt. you can tow it but not recommened for long hauls.
