trailer lights
Old Sep 21, 2009 | 04:25 PM
recliner's Avatar
trailer lights
my trailer i use to haul mower around, the left turn signal works on trailer, the right signal does not. is there a fuse in the 2003 f-150 that controls right or left turn signals for trailer. truck lights work good, right and left work good. right lamp on trailer has green and brown wires, i wired up green to green brown to brown. i thoght maybe there was a fuse i should check. thanks
Old Sep 22, 2009 | 01:19 AM
#19 in the underhood box, 10 amp. Refer to your owner's manual.
Old Sep 22, 2009 | 07:25 AM
APT's Avatar
APT
Check the power at the 4-pin connector. If there is power there, then one of your wires is not connected. If no power at the 4-pin, then fuse is a good place to start.
Owners manual lists all the fuses. If you have no hard copy, download a PDF from here.
Old Sep 22, 2009 | 09:01 AM
recliner's Avatar
thankyou sirs
Old Sep 22, 2009 | 12:33 PM
recliner's Avatar
if the left tirn signal works I'm getting power yes? could I still have a bad fuse even though the left works? thanks
Old Sep 22, 2009 | 01:37 PM
That fuse is for the right stop/turn on the trailer. There's a separate fuse for the left one. Again, refer to your owner's manual - if you don't have one, download it. The 4 wires are as follows - ground, running lights (both), left stop/turn, and right stop/turn.
Old Sep 23, 2009 | 05:54 AM
recliner's Avatar
thank you, you are a scholar and a gentleman.
Old Sep 23, 2009 | 08:43 AM
APT's Avatar
APT
I've seem GLC called lots of things, but never that.
Old Sep 23, 2009 | 12:11 PM
You are quite welcome!
