2008 Screw Payload vs. 2009 Screw Payload
How can you say there is no rule for payload? I think it's the limit or rating we should not exceed, right? I understand what you are getting at here, but as I stated, I am OVER the payload already. I'm not looking to find our what percentage (say 80%) of the payload rating I can comfortably carry. I am over by several hundred pounds (300-400). I recalculated weights yesterday and I may be closer to 725 pounds over the 1,329 the door sticker displays.
My trailer doesn't offer the capability to move cargo around to the rear of the trailer to adjust the tongue weight like my last travel trailer... at least properly to prevent stuff from moving around in transit and destroying cabinet finishes, flooring, etc. So, I am stuck with loading the storage compartment in the front of the trailer or the truck bed. Either way, it is payload or tongueweight. I'm sure payload ratings are not provided for just some additional data to look at - they are provided for a reason. I think exceeding the rating by 10-15% could be within reason once in a while, but 55%, that may be a serious stretch of the rules... or let's say the saftey factor. Would you agree?
I agree, the numbers are there for a reason, and you should know where your at. If your truck is rated to tow a 8800 trailer, and had a GCWR of 14500, that would leave 5700 which is basically you and the truck, no cargo. I'm with you on this one, who goes camping by them selves with no cargo?
at 1690 payload, plus 6900 trailer, plus 5700 truck, your running close to 100% GCWR at 14290. I'm looking forward to hearing the numbers when you hit the scale.
Should I tow it with overdrive off or on with the factory 20's (the trailer will be empty) when I go to pick it up in Mcadoo, PA
Should I tow it with overdrive off or on with the Saleen 23's on it when towing (trailer will be loaded 800lbs) to and from Raleigh, NC.
Also how can I tell if I can hold OD on or not.
It will be interesting to hear what your opinion is after you do the haul, but I would think you would be fine using OD when pulling that 1200 empty trailer home with the 20s. However, I would not even consider using OD when the quads are loaded with your 23s on that 355 axle. I doubt you would gain much because your RPM should be low anyhow.
You don't want it shifting out of OD on every hill. I think you have an Edge, and you can watch the temp, but it's more than a heat problem. It's also the pounding it takes shifting under load.
Greencrew, I have only 2 points. Running at GVWR is not the same as running at 10% over it. Some types of wear are accelerated, other types just break. Bolts break, springs and shocks wear out for example. Just because people do it does not make it right or safe or wise.
As a disclaimer, I will admit that even though I think I have traveled hundreds of miles at GVWR, I've never really weighed the truck. Also, I have never pulled an 8000lb trailer. The most I have ever pulled is about 5000lbs, with only me in the truck. I do know that a 5000 lb trailer affects the handling of the truck more than 1400 lbs of cargo. I just wondering if loading the 800 lbs of cargo helps the truck handle the 6000lb trailer any better.
I don't know all the answers, just thought it would be fun to jump in on the conversion and learn a little bit about doing the load math. It may be a dumb question, but I would rather ask it and have some clue when I'm towing.
