trailer tow package... need brake controller
Old Jan 12, 2009 | 07:07 AM
APT's Avatar
APT
The difference in cost for a cheap one ($75) and the Prodigy ($100) is minimal. The difference in installation time and braking performance in huge.
Old Jan 15, 2009 | 08:45 PM
tbyle's Avatar
I bought the P3 about a month ago. It is awesome. Now, I have no comparison since it is the first brake controller I have purchased. But, that may just be a good point to add. Installed in about 15 minutes and set up the controller with trailer attached in about 5 minutes.
During my research I was told that the Prodigy and P3 are very similar. The P3 just gives you status and errors in plain words and not codes.
I went with the P3 because others, my wife primarily, may be towing without me. Plain words to explain a problem seemed better than having to look through a manual when there are issues. We tow horses so towing can be stressful enough.
One last comment regarding the cost. $80, $100 or $150 is not much to fuss over when you look at the bigger picture. Big picture being $10K to $15K for a trailer plus $5K to $25K for the tow vehicle plus $2K to $5K for cargo.
Skip a few beers at the bar or a dinner out and go for the best brake controller, Prodigy or the P3.
-T
Old Feb 16, 2009 | 02:20 AM
effextwo's Avatar
Originally Posted by Colorado Osprey
Directly behind/above the OBDII diagnostic port. Grey connector.
And where/what is that? Because I'm in the same boat... I didn't even know I was gonna need such a thing. I'm renting a travel trailer this summer and apparently a brake controller is required. So now I need to get as much info as possible. I'm pretty mechanically inclined, but just want to plug and play. Is that gonna be possible?
DISREGARD...JUST PURCHASED A PRODIGY PROPORTIONAL (PART #90185)....
Old Feb 19, 2009 | 10:17 AM
ugly duck's Avatar
www.etRailer.com - and thanks for the tip! Mine's on order this morning.
Old Feb 19, 2009 | 10:51 AM
pmason718's Avatar
The Primus is just an economy version of the Prodigy.
The onboard diagnostics are improved in the Prodigy as well as an ability to mount it at more extreme dash angles.
Places like www.etailer.com actually have the Prodigy on sale cheaper than the Primus. ($98)
I would imagine that the Primus is going to be discontinued as a product.
That link is actually etrailer.com
How do brake controllers work. I understand the logic behind it and I thought that you had to press the buttons on the controller when pressing your brake pedal on the truck to work but I guess that's wrong. I see people mounting the really low and I'm like dam how do they reach it when braking, lol. Can some explain to me (towing newb) how this works.
Old Feb 19, 2009 | 12:21 PM
APT's Avatar
APT
pmason,
There is an accelerometer in proportional brake controllers that senses how much you are trying to brake the truck/trailer and determines how much trailer brakes to apply. Most of the time, the driver never needs to do anything different when braking than not towing. There is always an override that allows the driver to manually add more trailer braking, but this is not used for every stop.
Old Feb 19, 2009 | 01:28 PM
pmason718's Avatar
Originally Posted by APT
pmason,
With this being said is this unit plug n play. I'm not talking about wiring installation but can you take it out of the box, install it and start towing or do you have to put in some info. What I'm trying to get at is how does the controller know how much braking is needed for the trailer?
Old Feb 19, 2009 | 07:11 PM
kd4crs's Avatar
The braking force is adjustable and you set it during the initial installation. The accelerometer senses how quickly you decelerate the tow vehicle and modulates the electric brakes on the trailer to work in concert with the tow vehicle. There are various adjustments you can make to tweak the braking applied by the controller. You will need to read the instructions fully to set them correctly. I love my Prodigy. Once it is setup correctly you almost can't tell the trailer is back there when braking.
Old Feb 19, 2009 | 08:52 PM
lObOdiablO's Avatar
what is a break controller 4?
Old Feb 19, 2009 | 09:28 PM
Colorado Osprey's Avatar
To activate the trailer brakes as you are braking in the tow vehicle.
Without some type of brake controller, electric trailer brakes won't work.
Old Feb 19, 2009 | 11:01 PM
SilverLakeF150's Avatar
-T
I agree, why is everyone so worried about spending a couple of bucks to protect thousands of dollars worth of equipment? It really does not matter how often you tow/haul. The last time I checked my happy a** is worth the same no matter who or whatever I am doing.
Old Feb 19, 2009 | 11:48 PM
pmason718's Avatar
So were does the harness that comes with the truck in the plastic bag go. I decided to add electric brakes to my trailer b4 they build it. I want to buy a brake controller now.
Old Feb 20, 2009 | 07:21 AM
The loose wire ends will attach to the supplied wires that come on your brake controller. The connector end will plug into the truck... locations of this plug was the original post of this thread. 1997-2008 it is above the gas pedal on the bottom of the dash... above/behind the OBDII diagnostic port.
If you purchase a Prodigy or P3 you can get a wiring harness that is totally plug and play and no splicing is required. Costs about $15 (edited for correct price)
Old Feb 20, 2009 | 09:15 AM
pmason718's Avatar
If you purchase a Prodigy or P3 you can get a wiring harness that is totalloy plug and play and no splicing is required. Costs about $10-12
This is what I rather do. Can you or someone set me up on a website (who ever has the P3 cheaper) with the P3 and the plug n play connector, I'm ready to checkout.
Old Feb 20, 2009 | 09:49 AM
P3: $140
http://www.etrailer.com/pc-BC~90195.htm
or Prodigy: $99
http://www.etrailer.com/pc-BC~90185.htm
Wiring harness for either(same harness):$15
http://www.etrailer.com/p-3035-p.htm
That place has a low price pledge. If you find it cheaper elsewhere they beat it by 110% within 30 days.
Any purchases over $150 have free shipping... another reason for the P3??
