Towing question
Towing question
We recently traded in our popup camper (3000lb gross) for a travel trailer (7500lb gross, 4600lb dry). I haven't taken delivery of the new trailer yet, but want to make sure I'm all set to tow it. I got a nice brake controller from a friend and it's installed and working great. However, I'm a little concerned about my receiver hitch. I had someone look at it and it's not a stock Ford hitch, but there's no labeling, etc and it is pretty rusty. Is there anyway I can tell what the hitch is rated at? I can't see anything, but maybe I'm not looking in the right spot. My best guess is that it would be rated at 5000lb.
My second question is would I be better off putting money into a new hitch that covers the 7500lb, sticking with the existing hitch and adding a weight distribution hitch (can I do this as an add on), or should I really look at both?
My guess is that the trailer will weigh about 5500, maybe 6000lb in all actuality for how much gear we'll be adding.
It's a 2001 screw with about 110k miles on it. Hard to describe exactly how much rust is there, but there were some spots with several layers of rust that I could easily scrape off with a screw driver.
We usually go on about 6-8 camping trips a year, most being either 240 or 500 miles round trip.
Personally, I'd be happier getting new everything. That's quite a few trips. You can always sell that stuff later on down the road if need be, and as long as you take care of it you'll get a fair buck for it.
Thanks for the replies. I'm shooting for safe, but not overkill. Don't want to have something bad happen because I was too cheap to spend a few hundred dollars, but also didn't want to get too much overkill. It really sounds like the best option for me may be to go with a new WD hitch that can handle 7500lb.
Any recommendations for a decent hitch? I'll be checking with a few places tomorrow I think, but I'd like to get an idea for what it should cost me to buy one and get it installed.
glc, just to clarify your post. Are you saying a 5000lb rated hitch with a WD system can handle 10000lb?
Class 3 hitches are usually rated for 5000# straight and 10000# with WD. If your rust is just surface rust, you can probably clean it up and keep using your receiver. If it's a 2" receiver, it should be at least a class 3.
However, if in doubt, replace it.
