'06 xl 4.2L 4 wire flat to a 6 pole round and 4 wire flathelp / guidance
Old Sep 27, 2007 | 08:13 PM
Workingtruck's Avatar
Thanks in advance for entertaining my questions. If this question has already been answered please just direct me to it. I have an 2006 F150 XL with 4.2L it has a 4 pin connector and I need a 6 pole round for a new trailer. I have purchased a 4 wire flat to 6 pole round and 4 wire flat Hopkins Adapter. It says it is an easy installation, no cutting, no splicing, plug-in simple. My question(s) is/are. Where do I find the blue wire for electric brakes, and where do I find the (red) aux power wire. The 4 flat is obvious where it goes but for me to not cut or splice the red and blue, I must be missing something. Any help is truly appreciated.
Old Sep 27, 2007 | 10:08 PM
Follow the wires back from your 4 pin, up behind the spare tire. You should find everything you need back there.
Old Sep 27, 2007 | 10:26 PM
Thanks I will look into it tomorrow morning.
Old Sep 28, 2007 | 10:19 AM
I took the spare tire down and followed the original 4 pin back to a wiring harness that has a blue coming in and on the other side it has something like a blue dust plug on the opposite side. When I take the blue dust plug out it appears as though it will take a male connector of some sort maybe. The blue wire on the hopkins adapter has what looks like a male connector that once you place the blue male wire or connector in it you would crimp it. There is also on the truck wiring harness above the spare tire a orange wire coming in on the opposite side of the blue wire with again a blue dust plug on the outgoing side. The red wire on the hopkins adapter is the same as the blue with a female crimp type connector. Any ideas? Am I even looking at the right wiring harness on the truck? thanks again. Hopefully I explained it well enough.
Old Sep 28, 2007 | 12:01 PM
That is all for connecting a factory 7 pin connector. No crimping required.
http://www.etrailer.com/p-118242.htm
Old Sep 28, 2007 | 04:54 PM
Sorry if I am missing something. I need a 6 pole round connector for my new trailer.
Old Sep 28, 2007 | 10:31 PM
Colorado Osprey's Avatar
I am not aware of a 6 pin convertor that requires no splicing. The reason is there are 2 wiring schematics for the 6 pin plug. On the truck the orange wire is the 12v aux or trailer charge wire, and the blue wire is the trailer brake feed.
I would consider putting a 7 pin plug on the truck. This has been the standard in trailer wiring since 1997. There is no alternative wiring in the 7 pin so you know it is always right. If you get the wrong wiring schematic for the 6 pin it will lock up the trailer brakes.
My suggestion...move in to the 21st century and upgrade the truck and trailer to 7 pin.
Old Sep 29, 2007 | 11:25 AM
Thanks for the reply, is the 7 pin for the truck plug and play? How hard is it to convert the trailer?
Old Sep 29, 2007 | 04:20 PM
Yes and the trailer plug just requires the purchase of a new 7-way trailer plug as well as installing the 6 original trailer wires and putting them in the correct location in the new trailer plug.
Old Oct 1, 2007 | 09:46 PM
OK 7 pin it is, where do I connect the purple (BU) or reverse wire on the adapter?
Old Oct 2, 2007 | 07:48 AM
Ford's reverse wire is brown with a green trace. It is in that wire bundle on the harness.
Old Oct 2, 2007 | 01:46 PM
Thanks again. Does it matter that the wire going to the reverse light is black with pink?
Old Oct 2, 2007 | 03:00 PM
another possibly dumb question...
Do I have to purchase a brake controller, or is there already one in the truck? The truck came with only a 4 pin flat from the factory???
Old Oct 2, 2007 | 03:25 PM
You need to get a brake controller. There is a plug for it back there somewhere behind the dash. It will work as long as the harness at the back end of the truck is properly terminated in a 7 pin connector and you put the relays in.
Old Oct 2, 2007 | 10:08 PM
What will work?
I will get a brake controller.
And also from what I gather, I need to get and install some relays...
