Towing question
Old Sep 1, 2007 | 09:52 AM
06screwon22s's Avatar
Question Towing question
I just recently got 22's put on my 2006 Screw with Kuhmo 305/40/22 tires. Will I still be able to tow my boat (approx 3000 lbs with trailer) without putting too much stress on the smaller tires? Thanks.
Old Sep 1, 2007 | 11:04 AM
What is the load rating on those tires (look on the sidewall) compared to the stock tires?
Old Sep 1, 2007 | 11:17 AM
scott1981's Avatar
Yes, thats a tongue weight of around 300 lbs, that will not be a problem for any truck tire on the market to hold. your fine
Old Sep 1, 2007 | 11:21 AM
Colorado Osprey's Avatar
It's a little more complicated than that.
You have low profile tires which make it easier while loaded to accidently ding a wheel with even a small pot hole...which could cause a tire or wheel failure.
Secondly large diameter street wheel like 22" do not have much of a load capacity like normal 16-17" truck wheels....and usually don't even have a weight rating greater than 1700#'s for each wheel. Next the tires to have the speed rating with that low of a profile tire can not be constructed to carry loads and have a load range of A or B. Kumho doesn't list spec of their web site so you will need to look on the tires for weight capacity.
Now to try and answer the question:
Pulling a 3000# boat.
You could possibly have only 300#'s of tonge weight which will have no significance on the truck weight or tire choice.
You could have a 3000# boat with 600 plus #'s of tongue weight which your new tires possible could not handle.
It is a little difficult to answer without a little more information on the boat/trailer besides just the wight of the boat.
Old Sep 1, 2007 | 02:02 PM
Thanks for the info guys. The trailer is a standard "float-on" for a 21 ft boat. It is long and aluminum so therefore the weight at the tongue is relatively light; I can lift it off the ground "on a good day" so I would say the weight at the tongue is no more than 350-400 lbs.
Old Sep 4, 2007 | 01:57 PM
BrewScrew's Avatar
45s and you would be real good
Old Sep 4, 2007 | 03:05 PM
Bryndon's Avatar
350# tongue weight is the absolute minimum that should be there - 3000# boat, 500# trailer (REALLY light trailer) @ 10% tongue weight. Bumper pull trailers should be minimum 10% to max 15% - 13-14% is where they tow the best. You are really probably below 10% - which means the axle is mounted too far forward on the trailer.
Anyway, all that said, the aluminum trailer doesn't cause the tongue weight to be low - length doesn't really matter either, although a longer trailer will tow better with a lower tongue weight. Bottom line is (as Colorado said) you need more details for towing with those wheels and tires.
The game plays like this...
Scale the truck (you need a rear weight) be sure to include everything as loaded for hauling, including passengers - that gives you a real rear weight. Check the tire and wheel capacity (could be a lot different). The weakest link in the chain is the thing you are looking for - if the are the weak link and tires are rated at 1700# each, you have 3400# to work with - less the rear weight of the truck (I'd guess about 2600# although I've never checked). If the tongue weight is 400#, based on the rest of the details being in line, you'd be OK.
Old Sep 7, 2007 | 11:02 AM
Thanks. The load rating on the side of the tires is 2600 lbs max load. The tires are Kuhmo Ecsta's, specifically made for large trucks/SUV's.
Old Sep 7, 2007 | 12:23 PM
2600 sounds like more than enough for your load.
Old Sep 7, 2007 | 12:28 PM
Bryndon's Avatar
What the rim limit? It could be lower than the tire. You just want to make sure the weakest link is strong enough to do the job.
