slide in camper
Old Aug 30, 2007 | 05:23 PM
diesel350's Avatar
slide in camper
have 2006 f-150 supercrew 5.5 ft bed anyone have a slide in if so which one thanks
Old Aug 30, 2007 | 08:44 PM
Colorado Osprey's Avatar
You will be hard pressed to find a modern slide-in that won't exceed your GVW ratings in any half ton truck. Most camper salesman will not tell you this fact though. Slide in campers are best left for 1 ton trucks.
If you must...there are some stripped out units, without water and stove that should work, but after adding your gear to them you will be heavy and you will need to alter your rear suspension to compensate for the load.
Old Aug 31, 2007 | 09:55 AM
Bryndon's Avatar
X2. The Diesel 350 makes a lot more sense. Most campers are heavy enough to make a 1-ton squat.
