Where to buy relays?
Old Aug 30, 2007 | 03:40 PM
red06f150's Avatar
Hey guys,
I was wondering if someone can tell me the best place to buy the towing relays. I've tried my local kragen and they don't carry them, as well as the Ford stealership, and they wanted $25 a piece. That seems alittle steep. So can someone tell me where they found them, and if at all possible the parts numbers. Its a 2006 F150. I need all 3 relays that are associated with the towing package. Thank you,
Nick
Old Aug 30, 2007 | 09:56 PM
TT_SCAB_05's Avatar
I dont have part numbers but I got generic after market relays for like $5 each at autozone. They work fine and are the same as the ford relays without the ford logo.
Old Aug 31, 2007 | 03:43 AM
red06f150's Avatar
What did you ask for when you went in there. Because i went in to Kragen and they looked at me like i was from Mars. But i'll have to give Autzone a chance. Thank you once again TT.
Old Aug 31, 2007 | 05:02 AM
SSCULLY's Avatar
Autozone it should be :
Duralast / Relay - Multiple Purpose
Part Number: 19283
$15.99
I think this is the full size ISO relay
There is also a Part Number: 19273 for $ 8.99, but I think this is the half size version ??
The part number listed in the 2006 trailer tow directions is F0AB-14B192-A ( maybe that should be F0AB-14B192-AA ? ), for the full size one.
The half size you are also going to need, for the trailer tow park lamps.
You can pull the hi beam headlamp relay ( R03 ) for an example of the full size. Without factory fog lamps, the only example of the half size is the PCM relay, or if you have the DRLs disabled, with R03 in the Aux Relay box under the hood on the passenger fender.
Good luck, if nothing else, try one of the online parts places. Send them an email, asking for one of each, and refer to the owners manual placement, so they can get the correct relay #
Old Aug 31, 2007 | 05:10 AM
SSCULLY's Avatar
Found the other thread, with some different part numbers from Autozone
Another member got the full ISO Relay ( for the interior lights ) which crossed to : The Autozone number is #325595 41-5162
This is a GP Sorenson relay # 41-5162. This is the P/N for the Full ISO relay, if AutoZone has these, I would think they could cross to the 1/2 Relay as well.
Here is the thread that I got it out of:
https://www.f150online.com/forums/sh...relay+autozone
Old Aug 31, 2007 | 10:31 AM
red06f150's Avatar
You don't know how appreciative i am of this. This darn relay thing has been driving me crazy. Thank you both,
Nick
Old Mar 27, 2014 | 01:56 PM
Jordden's Avatar
Exclamation 2008 f150
Hey how everyone doing? This might not be the right site but I figured I would check and see anyways. I have a 2008 F150 4.6 L, and one day when I clicked the auto lock the horn just stayed on and I don't know why. I have checked the fuse box and there is not a relay (according to the owners guide) that controls the horn. I tested voltage at the horn connection the horn is always being sent 12v now.... I checked the resistance on the horn it is within parameters. It just seems like its just always being sent power.... any idea's?
Old Mar 27, 2014 | 02:28 PM
I would contact a moderator and have your post moved to the electrical section. You just tacked your reply onto a thread in the towing section that's been dead for 7 years.
