Trailer Lighting Fuse
Old May 21, 2007 | 07:49 PM
dubbass33's Avatar
Can someone help me out with where the fuse is for the trailer wiring harness in my 97 f150?
Old May 21, 2007 | 08:23 PM
bigdad8214's Avatar
Running light fuse is the same as the running lights for the truck. Same with the brake light fuse.
Is that what you mean?
Old May 21, 2007 | 09:14 PM
dubbass33's Avatar
the harness that the trailer plug plugs into got ripped off, so it has been just wires hanging there and i figured it probably shorted out the fuse over the past 2 years being like that, so i wondered if there was a fuse and where it is, or if anything else would have happened.
Old May 21, 2007 | 09:51 PM
bigdad8214's Avatar
Well if everything else is working then I would have to say you are ok. You could always get a test light and see if you got power back there so you know if you got problems. I would just make sure there is no bare wires and tape them up.
Old May 22, 2007 | 07:22 AM
dubbass33's Avatar
alright thanks
Old May 22, 2007 | 12:28 PM
2stroked's Avatar
There's a small, unmarked fuse box for the trailer stuff under your hood on the driver's side. It usually got a piece of electical / friction tape holding it shut from the factory. You have to really search your Owner's Manual to find it.
Old May 22, 2007 | 04:22 PM
dubbass33's Avatar
just checked that and that's what i needed. thanks
