Maximum Theoretical Towing Capability F150
Old Jan 27, 2007 | 01:37 AM
montuzumasviper's Avatar
I know this isn't practical what so ever but i have often wondered how much you could theoretically pull on dry level payment in 4 wheel low in a straight line if you consider you have minimum tongue weight or a fifth wheel. Something along the lines of pulling a very large sail boat or maybe a semi sized load. I realize tire traction would probably come into play far before engine capability would but i'm wondering.
Your in a say, 2007 with the highest rated towing capacity (I have 99 navigator btw)
So if you consider maximum engine torque, transmission-rear end ratio, torque conversion (all stock parts of course) what might you get?
Old Jan 27, 2007 | 07:03 PM
Colorado Osprey's Avatar
I think you are asking 2 different things.....
Maximum towable.....and maximum pullable or movable.
Maximum towable is listed in the owners manual as well as a sticky on the top of the towing and hauling thread for a particular model as options apply.
Maximum pullable or movable weight will be quite hard to determine. There are many factors.....most of which will be the pavement and the tires....as well as the weight of the truck with the added weight of the trailer tongue.
Excluding the fact that you will probably burn up the transmission in an automatic....or burning up a clutch in a manual transmission you could probably move....or get moving on level ground probably around 40,000lbs maybe more on say a hay wagon that has no real tongue weight as it has tires in all corners of the trailer.
Old Jan 27, 2007 | 08:32 PM
Zaairman's Avatar
Maximum safely and legally you can tow or just maximum fully loaded once in a lifetime type of thing? I've hooked up to a load before (0 lbs tongue weight besides the chain), and dragged it fine, but my tires were spinning.
Old Jan 28, 2007 | 12:28 AM
chrism9232's Avatar
what about in 4low
Old Jan 28, 2007 | 12:34 AM
Zaairman's Avatar
Originally Posted by chrism9232
what about in 4low
It really depends on a lot of things. Tires WILL blow out when way overloaded. Suspension parts WILL break. Hitch parts WILL bend and break. It depends how you can hook up to it. If you are just chaining up to something, then you are basically traction limited, until something breaks. As for towing, it's really just what you can fit on the trailer. Just don't go out on any roads near me.
Old Jan 29, 2007 | 01:15 AM
chrism9232's Avatar
https://www.f150online.com/forums/im...milies/lol.gif
Old Jan 29, 2007 | 11:55 AM
SRockwood's Avatar
Enter a tractor pull contest and let us know...
Old Jan 29, 2007 | 01:22 PM
Zaairman's Avatar
Haha...I thought about doing that over the summer for fun at one of the county fairs, but couldn't find an entry form.
Old Jan 29, 2007 | 01:23 PM
MitchF150's Avatar
I'm surprised that Chester is not all over this one!!
Mitch
Old Jan 29, 2007 | 02:49 PM
jmt0645's Avatar
Mitch
me too
Old Jan 30, 2007 | 01:20 AM
chrism9232's Avatar
anyone on here ever do that
Old Jan 30, 2007 | 01:27 AM
Zaairman's Avatar
Not yet...maybe this summer if I can make it out to one of the many county fairs.
Old Jan 30, 2007 | 01:33 AM
chrism9232's Avatar
Old Jan 30, 2007 | 01:52 AM
Zaairman's Avatar
Already answered your question 5 mins ago...
Old Feb 4, 2007 | 11:40 AM
Whapt's Avatar
I am going to enter a truck pull with my truck it's only the 4.2 with a 5sp and 4x4 i will let ya know. last year a friend only pulled 4 feet with his chevy and got second because there was 3 in the class and 1 broke
