3:55 to 4:10 pricing
i went from the strock tires (tiny) to huge 285/75/16 tires and i pull a trailer im wondering how much it would cost to convert the gears. and should i move to a larger gear than the 4:10 if so what are my options
You're probably looking at around $500. per axle. I have a 4x4 so it was double the cost. I wouldn't go any lower than 4:10 unless you're going to pull something heavy and often. 4:10's will give you better accelleration without burning too much gas. You should pick up about 400 rpms.
https://www.f150online.com/galleries....cfm?gnum=7238
