Do you guys think I will be ok???
I am looking at buying a toy hauler and I want to know if I will be able to tow it safetly tell me what you guys think?
Here is what I have:
02 Ford F150 Supercrew, 4X4, 4.6 V8, 3.55 gears, 6500# GVWR package, and trailer towing group class III with trans cooler.
The Trailer I am looking at is:
07 Weekend Warrior superlite 19' with a dry weight of 4700lbs, that includes all options. The total weight of the trailer loaded with quads, half a tank of water and gear is around 6300lbs. But I will not always fill up water and be takeing the quads, that is the most it would weigh if I took everything.
What do you think???
Provided the hitch and receiver are rated to haul that (both tongue weight and tow capacity) you won't have any problems towing that with the 4.6. You won't be breaking any land speed records, but you won't have any issues with towing that much weight. A friend of mine hauls his 26ft boat with his '06 F150, and I believe it weighs somewhere around 8000lbs, and he does this twice a month at least. His trailer is obviously a dual axle with brakes, and his truck's hitch is rated to tow that much weight.
One thing to consider though, does the trailer have surge brakes? If it doesn't, getting that much weight pushing on you while trying to slow down might be a bit of a problem. Also, is the trailer a single or dual axle??
Tanner
Originally Posted by Tanner_F150
jt29,
Tanner
Tanner
Best thing is to load it up fully and take it to some scales.
Check the Gross Combined Rating and Gross Axle Ratings, too.
My 2002 screw is similar to yours but I have the 5.4. I max out the GCWR first because the truck is so heavy. My trailer is about 5500 lbs loaded.
Don't forget that water is just over 8 lbs per gallon. I tow with just enough water to get me where I'm going and then fill up there. I always dump the grey and black tanks before I leave to come home.
i pull a 18' titan toy hauler and i place 3 dirtbikes in it . with everything loaded it ways about 5,500 and im ok around 60mph.
i was looking at weekend warriors and i was just about to buy one when i founf a funrunner titan which was almost half the price and just as well made despite what weekend worrior owners may tell you i take it out every weekend about 130 miles round trip. it did cost me 13,000$
Originally Posted by expy03
Best advice. Seen alot of problems with people pulling over loaded toy trailers headed for the dunes. The only way to be sure is hit the scales.
Is that the dry weight rating from WW or what someone actually weighed? RV's and especially Toy haulers are notoious for fudging the weight numbers. Many WW owners @ RV.net that weight their trailers are are 10-15% over the dry weight rating when they pick them up from the dealer.
What about the Travelstar 23TB? Larger, but lighter. Or the 18SD if you can handle open sotrage for the toys.
