Do you guys really to 8-9K With Your 150's?
Originally Posted by Magnawake
When I stated, Going back to 150's, they are never satisfied. What I meant was, once you get used to the grunt of a 250, the 150 seems weak. One day I might get a 250 psd. Once you get used to a Caddilac, an LTD just wont do. However, it will get the job done.
Dont get me wrong, I still like my truck. It looks good, drives good and empty, it has good power (always want more).
Seriously considering some 4.10's for this truck, but since 95% of the time, it is just a weekend cruiser, I'll be spending money to burn more gas.
You guys talk about 4.10's, 3.55's. Is that the gear ratio you are speaking of? I just got my truck, and am a little disapointed at the MPG. Ford says 18 hwy 14 city. The 1st tank of gas was 13.4mpg, and mostly hwy. I did not baby it though. I have a 5.4L, 4.10 rear end, 163in wheel base, tow package, extra capacity package. Ford says I can tow 9300lbs. I don't know. This weekend I got a load if mulch, piled 3ft over the bed. Tarped it and drove home...I didn't even know it was there. The total wt was 8000lbs. I think they said 8200 was max. The truck didn't even squat. GREAT TRUCK.
Does the 4.10's give it better MPG?
--Rick
--Rick
Originally Posted by APT
I get 12mpg average w/ my 03 Screw 4x4. Never gotten more than 14.2mpg Towing, 10-11mpg.
Yes, it depends on how you drive. However, for the same driving conditions and styles, a PSD will get better than an F-150. If someone already has a PSD, there's no fuel savings going to an F-150. You just lose depreciation on the truck and towing/payload capacity. for a softer ride.
Every one of my friends that I race with get about the same mileage as me, and since we're in the same class, we're towing about the same weight. Unloaded, most of them get upper teens, same as me. Loaded, most of them get 15-17mpg, about the same as me, maybe marginally better. We even tow together sometimes, so speed isn't a factor.
However, I am the only one who can make a u-turn on a residential street. Hell, most of them can barely make u-turns in cul-de-sacs and 2 lane (per side) roads. For a while, diesel was also more expensive than regular. Would I rather tow with an F250? Hell yeah, you can never have "too much" tow vehicle. You can, however, have too much daily driver/commuter. None of my friends daily drove their F250/F350s for more than a month before buying a commuter or motorcycle.
Coolest tow vehicle? My friend tows with a '78 Buick Estate wagon (AKA Hearse!) with a 440ci big block. Wouldn't want to actually tow with it, but cool nonetheless...
Originally Posted by SRockwood
If you compared two F250s, one with a PSD, the other with a 5.4L gasser, then you'd be correct, but unless you're towing more than 5000lbs, you aren't going to see much difference between a F150 and a F250+ until you go up steep grades (with the PSD, of course).
Why would the turning radius of a Superduty be significantly more than the same bed/cab length F-150? I didn't find the specs @ Fordvehicles.com to verify.
Now I went back to a 2006 F-250 Stroke and anything I haul isn't a problem - except the daily commute is a rough ride, and diesel 'aint cheap.
Originally Posted by Raoul
If there if one thing the F150 is well suited for, it's towing a pop-up with it's low wind resistance.
A F250 Diesel pulling a pop-up is an embarrasment to all us Ford owners.
Don't you dare!!
Don't you dare!!
Do I really pull 8-9K with my f-150? Sometimes. It's according to which time of year it is. I mostly stay around the 15-18K range. Occasionally I pull something 25K+ But I'm not trying to win any speed races. Just getting my junk down the road....
Just picked this boat up this week, 2006 23' Centurion Enzo listed at 3500lbs + the trailer +46 gal fuel tank + gear. Pulled the grades at 65mph thanks to the Troyer 91 tow tune. Sure you could feel the weight back there but the truck felt solid.
Now to have a custom set of airbags installed for the 6" lift, sags just a bit.
i tow about 9500lbs everyweekend with mine, and it pulls it fine. of course you can tell its back there but it does pull nice. here is the link to a pic of it.
https://www.f150online.com/galleries....cfm?num=11490
