trailer plug
Old Jan 30, 2006 | 09:26 PM
edrife's Avatar
trailer plug
Hey guys, I got a 1997 F150 flareside 4x4 4.6 auto...I got an adapter for my trailer plug and can only get park lights....all the fuses check good in and outside the cab....any thoughts..thanks..
Old Feb 2, 2006 | 10:38 AM
Colorado Osprey's Avatar
is your truck wired for 4 pin and 7 pin like it came from the factory?
Which adaptor are you referring to?
Have you checked the truck-trailer fuses under the hood?
Old Feb 3, 2006 | 02:11 PM
1gr8gem's Avatar
get a meter, put the adper on the truck, function test the pins on the plug to find out what pin goes to what by turning on the blinkers --ect, then take a small jumper wire and stick in the pin thet you know the function of on the truck and stick the jumper into the pin on the trailer to determin what lights up, they have small checkers at any auto parts store, about 10 buks or less. hope this helps, Gary
https://www.f150online.com/galleries...w.cfm?num=8996
