Towing PROBLEMS!!!
Towing PROBLEMS!!!
New to the board here. Ive had my F150 for about 2 months and love it. It is a 1997 Lariat with a 4.6 and 4x4. I race Supersport motorcycles and haul an enclosed trailer. My trailer is a Horton V-nose with dual axles and brakes on all 4 wheels. Trailer weight is 1700lbs. With 2 bikes, tools and gear Im weighing in at 3k pounds give ot take 50 lbs. Problem is the truck STRUGGLES and only gets ~8mpg. I was really hoping for better performance. As for the milage Ive read several posts of people pulling car haulers(loaded with cars) getting better milage. What gives?
Any suggestions on ways to get better power or milage towing? Im starting the think my only other option in diesel
BTW: I tow with OD off.
![Mad](https://www.f150online.com/forums/images/smilies/mad.gif)
i get 9ish towing an open car hauler at 5k lbs. I have the 5.4 with 3.55LS. I only turn off the OD when in the mountains or the trans starts to hunt. What speed and rpm are you driving at? What is you mpg when unloaded?
Driving style plays apart. ease on the gas, don't follow close so you can maintain speed.
Try backing off a little and running in the low to mid 60's with it and see how that affects your milage. I tow at just below 60 with OD off. I can run OD on, but it'll down shift with any variation in conditions.
As far as performance, well, I've got the 5.4, and with 6500#'s it's not gonna win any races for sure. 60mph is all I feel comfortable pulling that weight on a flat surface. It just works too hard otherwise. I think the 97 is prior to the upgrade in power on that engine also.
edit: wow, my spelling was WAY off the first time around on this post
![help](https://www.f150online.com/forums/images/smilies/help.gif)
I have a 3 horse trailer which has similar aerodynamics as your enclosed (I mainly haul my CBR's in mine also
Wind resistance makes the most difference when hauling... on a trip from florida to alaska, I got 4-6 mpg in midwest with mostly headwinds (and also that crappy corn gas). In alaska, I got closer to 9 or 10 mpg, and this was where all the hills were! In the SE US, (ie: flat) I got 6 mpg at 65-70 mph, and 9 at 55-60 mph, and over 10 at 45 mph. Weight has alot less to do mpg than wind resistance with and enclosed trailer (speed).
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
