Brake Controller
Old May 5, 2005 | 06:30 PM
Debbie97224's Avatar
Brake Controller
Any suggestions for a good brake controller? I pull a horse trailer. Thanks
Old May 5, 2005 | 09:45 PM
cliles55's Avatar
Tekonsha is a popular manufacturer; their website address
http://www.tekonsha.com Check out their product and then go to ebay.com where you can bid and, more than likely, pay less. You'll need the pigtail from the truck to the controller, lencohitches.com is where I got mine; about $15.00 or less. That connector is under the dash, next to the diagnostic port. The plug goes there and the pigtail should have the correct color of wires you splice to the controller.
Old May 6, 2005 | 07:28 AM
APT's Avatar
APT
Tekocha Prodigy. There are cheaper models, but this one is so easy to set up and the brakes are applied so smoothly.
Old May 29, 2005 | 05:45 PM
Colorado Osprey's Avatar
There are none better on the maket today!
Old May 29, 2005 | 11:51 PM
WVtrucker's Avatar
I have been really happy with my POD (power on demand) controler I bought from etrailer (not sure who makes it). It was about $40 and I have been really happy with it. I don't tow a lot so I figured why spend the extra money for something I don't use much.
My $0.02
Old May 30, 2005 | 12:34 PM
mitchman's Avatar
I'd suggest the Brake Smart brake controller. Slightly more difficult to install than the Tekocha Prodigy due to the connection to your brake master cylinder, but it requires a lot less adjustment once it's installed.
We tow our sportscar to track events and sometimes we tow the trailer empty. I don't have to worry about adjusting the controller for changing load weights. (don't know if this applys to you or not)
I also like how the Brake Smart sends voltage to my trailer depending on how much brake pressure I'm applying. This is the same way the new F250/F350 OEM built-in brake controllers work. When I have to dynamite the brakes in an emergency, I know that the controller will supply full voltage to my trailer (this wasn't the case with my old standard controller)
The Tekocha is still cheaper though....
Mitch
'05 SuperCrew FX4
Old May 30, 2005 | 01:06 PM
The prodigy does all the same, but doesn't connect into the brake hydraulic system. It uses inertia sensor to see how hard you are appling your brakes and mimmics what you are doing to the truck with the trailer.
Old Jun 1, 2005 | 07:22 PM
KBrown's Avatar
100% recommend the Prodigy.
Old Jun 1, 2005 | 08:28 PM
Our customers choose the prodigy 50 to 1 of anything else. We carry 12 different makes too.
Old Jun 2, 2005 | 05:37 PM
snkbtn99's Avatar
100%. I tow a 3500 lb car w/ a 1700 lb trailer and you dont even know it is there when braking with the Prodigy. Best $99 I ever spent.
