Towing With Air Helper Springs
DOSE ANYONE USE AIR HELPER SPRINGS TO TOW YOUR CAMPER. I WOULD LIKE TO KNOW IF THEY ARE A GOOD BUY OR NOT.I TOW A 6000 POUND CAMPER WITH A F150 SCREW IT IS A TAG ALONG CAMPER I HAVE THE EQUILIZERS I DIDNT KNOW IF THE SPRINGS WOULD HELP WITH THE 2INCH SAG ANY INFORMATION WOULD BE GOOD. THANKS
I"ve run Firestone airbags for about 4 years now and they work great. Trucks these days are sprung pretty light to make the empty ride car like. The airbags do an awesomw job of helping the truck run level and prevent bottoming. My 20ft tandem axle holiday trailer has been converted to haul two quads and is pretty heavy. I also haul dirt bikes, gas, water etc. in the truck bed. I've weighed in at: 7400lbs on the truck axles, and 6200 on the on the trailer axles. workin hard but pulls fine. 97f150 4x4 5.4L.
Do you know what kit you got from firestone? I have a 99 and it should fit that too right? I emailed firestone and they didn't have a "ride-rite" kit for the truck, all they had was the "sport-rite". Do you think the system you have could be used when pulling a 27 5th wheel that weighs about 6800lbs on an extended cab 99? Thanks
