3" spindle lift
these are easy to install.you need a ball joint seperater.just take the factory spindles off,seperate from upper and lower ball joint,take off tierod end from spindle and take off the abs sensor and reconnect every thing to the new spindle.i needed a alligment kit,which i picked up for 40.00 at a local truck shop,and then an alignment and it was ready to go.
the rear you can use blocks which are easy to install also.
02,
Yes, make sure you get the rear blocks too. Otherwise it will be very high in the front and low in the back. Make sure the places quote you prices for both. I think at truckperformance the whole kit is about $650.00. I was quoted $1100 for the lift and align here in Dallas.
Will
Will
