Sponsored by: CARiD
Gears...
Old Jan 29, 2002 | 01:44 AM
FordMX's Avatar
Red face Gears...
Hey all,
I have decided to go ahead and change from 3.55 to 4.56's. The problem is I don't know jack crap about manufacturers or installation. So here are my questions...
1) How much should I expect for installation on a 2 wheel drive (1 axle)?
2) Who makes the best kits, and how much do they cost? Do I just need to order the "ring and pinion" kit, or are there other things?
3) Can I still install new gears if I have a shift improvement kit in my truck without hurting it?
Thanks everyone!
Chris
Old Jan 29, 2002 | 02:57 AM
y2kboti's Avatar
#1 - Install on just a rear axle should run would about $500-700 including labor and parts depending on what brand gears you select
#2 - I would go with Precision Gear. Their gears are heated treated better than most others. They are more expensive but you get what you pay for
#3 - You should not have any problems even though you have a shift kit. You may want to look into a programmer such as Hypertech so you can correct the speedo after the gear swap
Old Jan 29, 2002 | 06:16 PM
FordMX's Avatar
y2kboti,
Thanks for your help. Even being the Ford purist that I am, you have on sweet looking ride there...I don't know, there is just something about black lifted trucks that you can't go wrong with...just thought I'd drop a compliment to a (shhhhhh don't tell anyone) chevy for a change....
Chris
Old Jan 29, 2002 | 09:32 PM
y2kboti's Avatar
Thanks FordMX!
Old Jan 30, 2002 | 01:08 AM
V6runner's Avatar
gears
I believe 98's have a speed sensor gear in the trans so you can change that and not have to electronically reprogram.
The gears should cost 175
install kit w/ new bearings 80
labor different everywhere
I have 4.56 with 32's, going to be 33's
where are you in CA.
Old Jan 30, 2002 | 09:44 AM
FordMX's Avatar
Talking
y2kboti- no problem!
v6runner- Thanks for your help, I'm in Paso Robles, CA....central coast if you don't know where that is....
Thanks,
Chris
