Sponsored by: CARiD
front lift
Old Dec 17, 2001 | 04:33 AM
nace19's Avatar
front lift
what can i do to lift the front of my 97 reg cab so it is level with the back?would i have to change the front shocks if i did this?and how much bigger of a tire can i fit after this?thanks
Old Jan 3, 2002 | 10:32 AM
ChaoticRacer's Avatar
2wd or 4wd?
Old Jan 3, 2002 | 11:49 AM
tlapan93's Avatar
my thoughts exactly
2WD: You can put blocks in the springs to give it some extra lift.
4WD: Crank up the torsion bars. Make sure you are on level ground and measure eactly on both sides. The bolts are 18mm roughly directly under the middle of the cab, in the crossmember bar. Good luck
Old Jan 3, 2002 | 01:13 PM
If its a 2wd, get some coil spacers that sit beneith the springs or just get some lift coils(better idea). If its 4wd, only thing you can do is crank the bars up. Don't go over 2.5 inches though. Get it aligned either way
