Sponsored by: CARiD
Wheel Alignment Tools
Old Oct 15, 2021 | 09:43 AM
Besides using strings and measuring tapes, I would like to get something that is somewhat computerized.
I was looking at spending around $1,500 on the QuickTrick alignment system (https://quicktrickalignment.com/prod...yours-to-size/), but I'd like to know what other folks (or small shops) are using?
I also don't want anything that will consume a bay in my shop just for alignments or get in the way.
I can see it paying for itself in a few years of doing my own alignments as well as for close friends that I help out.
Max budget for this tool is around $2,000.
Old Oct 15, 2021 | 10:02 AM
Roadie's Avatar
I've been doing my toe-in alignments for decades with many variations of the tape measurements. I have placed wide boards against the front wheels with something heavy against them to hold them in place and measured the distance between the front and rear of the tires. I have jacked the wheels up and painted a white stripe in the middle of the tread and while still wet spun the tires and held a screwdriver in the paint to make a mark to measure the front and rear distance between the tires. Of course you have to wait until the paint dries and drive the vehicle back and forth enough to settle the suspension before measuring. Strings from the rear to the front work if you compensate for the difference in the wheel width between the rear tires and front tires. One reason I started doing my own alignments was that my front tires always wore more on one side when getting the "professional" alignments. After doing it myself, I haven't had that problem any more.
Old Oct 29, 2021 | 11:54 PM
tbear853's Avatar
I made a single toe measuring device of 1/2" plywood, a few screws, some glue, and attached aluminum feet for straight edges to guide my ball point pen as I mark tape on the floor, it's does not have to be perfect flat as any error when used on the right, say for example that it adds an 1/8" at the rear of the tire, it will compensate by adding the same to the left but then it's adding on the front of the tire. I have slots that let me adjust the plastic tipped thumb nutted bolts against the machined lip of the machined wheel. Once you've marked 4 corners, back the truck up and measure front and rear distances on the floor. I set my start end of my measure at the ten inch line on a steel tape, read the other end, twice, subtract 10, write it down. Then I measure the other pair the same way. For a 20" wheel, place slots at least 20" apart and as high off the floor as to center of wheel & tire.
I use level to check caster and camber. My floor is level.. Two floor tiles with grease between them placed under a tire is like a bearing turn plate.
Old Oct 30, 2021 | 02:16 AM
I've had one of these for 15 years. Gets me damn close at home in the garage
https://www.autozone.com/shop-and-ga...B&gclsrc=aw.ds
Old Oct 30, 2021 | 03:14 PM
^^ Wow!
This would fit the bill. I watched the video and it's exactly what I want. Even though it's not digital, the gauge makes it easy to read and fine tune adjustments.
I could double-check it's accuracy after doing a computerized alignment then notate it.
Patman -- you are awesome!
Old Nov 1, 2021 | 10:12 PM
^^ Wow!
heh thanks!
Biggest thing to remember is when you look at the gauge front/rear of the front tire, when you make adjustments, you should be doing half of what you need to do.
for example if you measure front and you zero it out, and then move it to the back and it reads -20. You would only perform adjustments to get the rear reading to -10
Old Nov 2, 2021 | 09:28 AM
Yep! I know what you mean by doing half.
It's like so simple of a tool for what I need!!
I got one on order now -- can't wait to test it!
Old Dec 25, 2021 | 06:44 PM
So I finally got around to testing the Specialty Products 46in to 74in Toe Measuring Gauge that Patman suggested.
Got it out of the box and it was easy to assemble and had instructions that came with it, that I keep in my toolbox in case I ever forget how to use it.
I brought one of my vehicles to have the alignment checked on a digital alignment system. Got a before and after printout.
I then drove it home and checked it with the Specialty Products alignment tool and it showed the exact same numbers that was on the printout. I noted it down for future reference.
I also got a cheap camber/caster gauge:
Amazon Amazon
That also came within what was on the paper, and noted that down for future reference.
I now know where my alignment needs to be in the future when I replace parts on that vehicle.
These tools will pay for themselves in one suspension/steering service.
Thank you Patman for the lead on this very nice tool. I like the fact it doesn't require power/batteries. It seems as if it's well built.
I appreciate it!
Old Apr 7, 2022 | 01:15 PM
tbear853's Avatar
Nice. Made one of them too, it works though. No math ... or vehicle moving needed needed either if tires are free to squirm like on greased tiles on the ramps or floor.
Old Apr 7, 2022 | 01:21 PM
tbear853's Avatar
double post?
