Can I fit a 37 inch tire on a 22 inch wheel
Decide which lift kit you want, then contact the manufacturer. A 6" lift may not be enough for your plans of 37" tires. I have a 6" lift with 35" tires. You should consider a 12" lift.
- Bulletproof Kit $3,590.00
- Atlas leaf springs $1,090.00
- Bulletproof 2.0 Reservoir shocks (Set of 2) $570.00
- Bulletproof 2.5 Coil Overs/Springs (Set of 2) $1,590.00
- NEW Front Coilover Reservoir Mounting Brackets ($25X2) $50.00
- Bulletproof Billet Shock Clamps ($30X4) $120.00
- Rear Traction Bars $760.00
- 4WD will require CV Front driveshaft $690.00
