Sponsored by: CARiD
Maxed out upper control arm
Old Apr 4, 2018 | 03:10 AM
5.4rico's Avatar
Hey guys, so I have a 99 F150 2wd that I lifted 5 inches. First thing I did after I installed jt the next day was get it aligned. It aligned well drives straight minus a slight pull to the right that it always did before thts not what bothers me. So the problem is that my upper control arm is I guess you can say maxed out. And my wheels have negative camber I’m guessing because of ghe control arms. How can I fix that. I have no idea how , I’ve searched for hours for extended upper control arms or some other fix with no luck. In case it matters the lift kit was 3 inch spindles, new shocks all around 2 inch lift springs ( that’s what gave it a total of 5 inches of lift) and lift blocks for the rear aaaand pictures!!
