Sponsored by: CARiD
is my Camber Adjustment maxed?
Old Mar 28, 2018 | 07:50 PM
Bruno123's Avatar
Hey guys so I went and got an alignment after replacing my front end. I have a '98 Ford F150 2wd with Rough Country Lift coils and I was told that the camber is at it's max adjustment. I have some negative camber that I did not have before? I do not know much about this stuff so I've attached pics of the Cams in hope someone here can help. Thanks in Advance! Passengers side
Passenger Side
Drivers Side
Drivers Side
Old Mar 28, 2018 | 08:04 PM
Get a camber kit. Usually the aftermarket ones have a bit more adjustment.
Old Mar 28, 2018 | 09:51 PM
Bruno123's Avatar
this is an aftermarket camber kit is it not?
Old Mar 29, 2018 | 06:34 PM
Not sure without measuring it.
Old Apr 4, 2018 | 03:32 AM
5.4rico's Avatar
I am having the same problem as you kind of, I have camber and my upper control arms are maxed.
Old Apr 4, 2018 | 09:50 AM
MKTRUCK's Avatar
25 Year Member
I don't recall if this would cause camber issues...Did you grind off the piece on the upper arm that may come in contact with the frame? https://s3.amazonaws.com/roughcountry/install/9268.pdf
I never had an issue on my '97 2wd.
