Sponsored by: CARiD
3" PA Body Lift Questions
Old Sep 21, 2001 | 11:35 AM
HuskerF150's Avatar
I'm new to the board.........
Has anyone had any problems with the body lift with their 4X4 F-150, other than a check engine light??? I just wonder what the manual transfer case shifter will look like on the floor with a 3" body lift. I have the floor shifter rather that the electronic 4X4 shifter.
Thanks in advance.
Old Sep 21, 2001 | 11:59 AM
rtroha's Avatar
What's this about a check engine light? I've got a 3" body lift on my truck and haven't had any problems with that light. My ABS light did come on but that was because the sensor wire wasn't properly tied down and it rubbed on the wheel until it broke.
About the shifter, I can't tell you because I have the electronic shift on mine.
Old Sep 21, 2001 | 12:44 PM
Donate54's Avatar
a body lift wonr make the engine light come on. if it does, then you probably knocked something loose.
Old Sep 21, 2001 | 02:12 PM
Flatlander's Avatar
Talking
I haven't had any problems yet, other than one of my drunk helpers broke the plastic sleeve on the transmission cable. They got it rigged enough that I haven't replaced it yet though (will do before winter).
Old Sep 24, 2001 | 09:10 AM
tlocke's Avatar
The manual 4X4 shift-lever will look the same because the kits include a spacer that gets welded onto the lever that extends it to the right length.
