Sponsored by: CARiD
Lowering question
Old Aug 30, 2016 | 04:24 PM
cwhitt's Avatar
Lowering question
I just ordered the Belltech 25001 +1 to -3 lowering struts. I have a '05 FX4.
Am I correct in assuming that to get a 2" drop, I would set the adjustment to -1 since the strut at 0 is a 2wd height? I've been running it in my head, just want to get a second opinion on it. My goal is not to go as low as I can, just to have a nice aggressive stance on it.
Also waiting on DJM 2" drop shackles to come in and I'll be set to go on this.
Old Aug 30, 2016 | 06:29 PM
I would recommend just buying factory 2wd struts, this will net just a hair less than 2" drop, but will retain factory ride quality
Old Aug 30, 2016 | 09:45 PM
cwhitt's Avatar
still thinking about it. My goal is to get the top of the fender arch at 35 inches.
I'm at 39.25" right now. Not sure if I have a 2 or 2.5" leveling spacer installed. I'll know when I take it out next week. I may just try to get some front struts from the junk yard and return the belltechs since I need a front grill, headlights, and leaf springs.
*note* do not clean front grill with brake cleaner. It is not the same material as the fender moldings.
Old Sep 6, 2016 | 10:43 PM
tbear853's Avatar
Between loosing the 2 or 2.5" spacer and going with 2wd front shocks (struts) .... you'll loose 4 or more inches height there at front.
Old Sep 7, 2016 | 08:30 AM
Agreed
