Sponsored by: CARiD
Difference between 4wd and 2wd
Old Nov 7, 2014 | 12:22 AM
Originally Posted by CJardine
Sweet, than I think I'm gonna go with the 4wd bilsteins and some rear risers. To add the risers do I need to buy new shackles or can I pull them off a junked 4wd. Are there any other incidental parts that need to be swapped/purchased or is it just the struts. Also I need to add tow hooks to the front that wont bend or pull out as nothing is currently there. Can I pull the OE ones of a junked one or go with aftermarket? Gonna see if I can get two welded on my hitch for the rear. They would be used for snatching and winching for rescue, now looking for show truck just ones that get the job done.
If by "risers," you mean blocks, then I'd just get some 2" blocks and new U bolts from Autospring. OEM from a junkyard would work, but that's too much effort for me to save a few dollars. Tow hooks can be purchased from Tascaparts, I would imagine. Because again, pulling them off a truck in the junkyard, I don't know if it's worth it haha. Junkyard parts aren't always cheap anymore either.
