Sponsored by: CARiD
2010 FX2 leveling kit ruin my tires?
Old Oct 15, 2014 | 09:05 AM
preluder5's Avatar
Let's see if you fellas can more less tell me what you think happened?
*Bought a 2010 FX2 in 2010-Installed a 2" CCM Offroad Performance leveling kit for the front (doughnut looking thing), and mechanic aligned truck
*At 12K miles, my tires were ruined on the outside, guess the alignment messed them up
*Replaced tires (had to spend $$$), got truck aligned again this time by FORD
*At 30K the tires got ruined AGAIN and once more I had to dish out $$$ for new tires and new alignment
*Thought all was well since I went about 26k miles worry free but NOPE... the drivers side tire has major thread wear on the inside part, the passenger not as much but there is some inner wear.
All I wanted to achieve was the look of the FX4 in terms of height, but it's been a nightmare and big hit in my pocket.
1)Do you all think the spacer/leveling kit I put on the front is to blame?
2)Do you think the mechanic didn't put it properly?
3)Should I replace the CCM Offroad Performance 2" leveling kit with something else?
4)Was I supposed to get an alignment every 6 months or once a year since I leveled the truck 2" in the front and 1.5" in the back?
I don't want to buy new tires until I know I won't have this issue again... any recommendations is much appreciated fellas. Thank you
Old Oct 15, 2014 | 10:55 AM
MGDfan's Avatar
Hi.
IMHO - 2" is starting to push the limits of the front-end geometry. Whenever you do a mod like this camber WILL change.
I reckon neither place aligned it correctly - and likely did not use a camber kit (which makes it easier and is at your expense). Did you obtain (a copy of) the alignment sheet showing the actual error and the corrections applied? That is your right.
Read:
https://www.f150online.com/forums/20...amber-kit.html
https://www.f150online.com/forums/20...eling-kit.html
I'd remove that crap and do it right - with adjustable struts in front at the very least. And find a shop that knows WTF they are doing ( and actually cares). Ensure you can review the adjustment data.
good luck
MGD
Old Oct 15, 2014 | 11:34 AM
Veteran: Army
Originally Posted by MGDfan
Hi.
Read:
good luck
MGD
/\/\/\/\ truth
Old Oct 15, 2014 | 11:39 AM
preluder5's Avatar
Pardon my knowledge but is a strut the same thing as a shock absorber? Can you point me to a link that has the "adjustable struts" you recommended? I tried looking at various websites but I have no idea what I'm to look for?
Hi.
Read:
good luck
MGD
Old Oct 15, 2014 | 11:52 AM
MGDfan's Avatar
Certainly.
Bilstein: http://www.bilsteinus.com/products/t...ht-adjustable/
Rancho: http://www.gorancho.com/shocks.php?s...ickLIFT_Loaded
A strut is a shock/spring assembly.
The Bilsteins are a tad firmer than the Ranchos. And more expensive.
EDIT: Rancho has a promotion going on fer a limited time. We also have a nice,friendly, Responsive Rancho Sponsor feller on this site - give him a shout ( Rancho Shocks ==> https://www.f150online.com/forums/me...ho+shocks.html )
MGD
Old Oct 15, 2014 | 12:09 PM
pizzaman711's Avatar
On top of what's been said, find an off road shop to do the alignment this time. They're used to working on vehicles where the geometry has been changed versus the dealership or places like that where they mainly service stock vehicles.
Old Oct 15, 2014 | 12:10 PM
MGDfan's Avatar
Thanks, Peetz - that thar is great advice!
MGD
Old Oct 15, 2014 | 12:28 PM
Rancho Shocks's Avatar
Former Sponsor
Red face
That's me!!! Thanks feel free to ask any questions here or PM. I wil do my best to answer them. Matt
Certainly.
MGD
Old Oct 21, 2014 | 10:40 PM
preluder5's Avatar
How much should a camber kit cost me with the service center that's going to install the rancho quick lift struts got? Are they only ordered online?
Hi.
Read:
good luck
MGD
Old Oct 21, 2014 | 10:59 PM
Former Sponsor
The bolts are around $80ish to $100ish or so. A lot are online but a shop will have access to them from a Wholesaler fairly quick.
Old Oct 29, 2014 | 12:46 PM
tyebo168's Avatar
Guess all trucks just aren't the same. I had a 2" spacer on my 2010 FX2 for almost 2 years. Tires are wearing perfectly.. I've recenlty took that off and put on a 4" RC lift kit sits much better now.. Good luck on what you do.
Old Oct 30, 2014 | 11:38 AM
jaws12's Avatar
In my experience driving fast and cornering hard can and will wear tires on the edges also.
Old Nov 1, 2014 | 09:19 PM
NASSTY's Avatar
I installed 2" leveling kits on my 06 and my 11 and a 1.5" kit on my 14 and they only threw the toe off a little but didn't mess with the camber or caster. Here are the results from the alignment on my '14.
